Where do you guys take your truck to get plugs and wires changed?
Old Sep 2, 2006 | 07:37 PM
paulv107's Avatar
I seriously need my plugs and wires changed on my truck. I have over 80,000 miles on the original ones. I have heard one of the plugs is very hard to get to plus I am not very good at working on cars.
So where would you guys recommend as a good place to go? I know there are the dealers, but I am thinking other repair shops might be cheaper. I don't have a great deal of money to spend but I really need this done.
Old Sep 2, 2006 | 07:54 PM
Peacemaker's Avatar
Try here.http://www.napaautocare.com/Locator/...lFacilityPos=8
Your location says North Florida, so I just typed in Tallahassee. You can put in any location or zip code and find one closer to you if you don't live near Tallahassee.
Hope that helps Paul.
Old Sep 2, 2006 | 08:21 PM
paulv107's Avatar
Actually I live in Jacksonville. I checked and found several. 2 of them are within 3 miles of my house. I'll have to call around on Tuesday and see what they charge.
Old Sep 2, 2006 | 09:52 PM
Peacemaker's Avatar
Old Sep 3, 2006 | 01:21 PM
BlueOvalFitter's Avatar
Talking
I change mine in my driveway.
Old Sep 3, 2006 | 04:17 PM
Paratrooper's Avatar
I also changed mine myself and it's not as bad as it is made out to be....
Buy a manual and do it yourself-the price of plugs and wires can be off-set by the labour you'll save.
Be sure to use the proper tools doing the plugs-you know like a plug socket with the rubber in it and a torque wrench so you don't crack the porceline on the plug.....
Old Sep 3, 2006 | 07:38 PM
Exclamation
A torque wrench? Pffffffft, just tighten them until you're blue in the face!
Seriously,don't forget the antiseize and dielectric grease.Also,go back with Motorcraft parts.
Old Sep 3, 2006 | 09:18 PM
Yea and I forgot the 6 foot long power bar to make sure they are real tight...
Good point to remember the dialectric grease and anti-seize.
Only one plug is a piece of work to get out, the others aren't so bad...
Giver 'er a shot, it'll save you some coin for sure...
Bill
Old Sep 3, 2006 | 09:25 PM
Peacemaker's Avatar
I did mine myself too. It wasn't too bad of a job. Re-routing the wires kind of aggrevated me a little though. Still running like a top.
Old Sep 3, 2006 | 09:26 PM
Peacemaker's Avatar
Werd. If you want to make sure it's done right...DIY.
Old Sep 4, 2006 | 01:16 AM
BoostedOne's Avatar
which one of these plugs is hard to get out?
None of them cant be done with simply a spark plug socket, 3" long extension, and a 3/8" drive ratchet.
Old Sep 4, 2006 | 07:52 AM
The back corner passenger side because of the damned EGR tube running in the way.
It's not that hard just harder than the driver's side. I had to go through the wheel well and put the socket on then go from the top to turn it. Still changing the plugs took me all of 20 minutes..
Old Sep 4, 2006 | 06:24 PM
f-150sport03's Avatar
I need to do this myself...and was wondering...
I've heard that high performance plugs & wires help out a lot. But others say to stick w/ motorcraft... What would YOU do???
Old Sep 4, 2006 | 07:55 PM
Stick with Motorcraft.
Old Sep 4, 2006 | 08:00 PM
Peacemaker's Avatar
I use Motorcraft Fine-wire plugs, and Autolite Professional Series plug wires with no problems. My engine runs alot smoother, and it feels like my engine picked up a little extra horsepower/trq.
