Cold Air Intake
Old Aug 29, 2006 | 09:23 PM
SweetRed'99's Avatar
Cold Air Intake
I've just recently installed a CAI, and I've heard something about disconnecting the battery for a little while, something to do with resetting the fuel curves?
Any info will be greatly appreciated.
Old Aug 30, 2006 | 11:01 AM
Peacemaker's Avatar
Yeah, take the negitive terminal off and turn your headlight switch on for 10-15 minutes. Then turn your headlight switch back off, and reconnect your negative battery terminal.
When you turn your key to the on position, all your gauges should sweep to the right, and then back to their original positions.
This indicates that your truck's ecu has been reset, and all sensors have been recalibrated.
It's a good idea to do this after every mod you do.
Old Aug 30, 2006 | 10:10 PM
Thanks.
