99' Identify Noise
Old Aug 24, 2006 | 08:21 AM
Andro's Avatar
99' Identify Noise
Hi, i think this should be the right place to pose this question. I recently inherited a 99 F150 XL from relatives, the truck is great and i am glad i've gotten it. However, increasingly over the past year i've been getting some weird noises from the truck and i'll try to describe it as best i can here. Hopefully somone can help me out.
The noise occurs only between 0-25 mph, after you shift into the next gear the noise goes away.
It sounds mostly like a dead cat however i guess a more accurate description would be vibrating metal. However because the noise goes away after you shift i don't think loose plates or anything could be the problem.
Has anyone experienced this? Or know of a better place to ask this.
Thanks in Advance,
Andro
Old Aug 24, 2006 | 09:14 AM
ChrisT's Avatar
check out this thread....
https://www.f150online.com/forums/sh...d.php?t=247484
not sure if this is your problem but good luck.
