View Full Version : Engine
  1. 2k 150 4.6 very laggy throtle responce
  2. Changed Plugs, now misfire on cyl 3+4
  3. VIN question
  4. eating oil
  5. Spark plugs stuck
  6. Fuel addatives
  7. whistlen a tune
  8. Will opening up Intake on PI heads lose TQ?
  9. Pressure coming out around gas cap
  10. Obdii Scanner's
  11. Grinding noise
  12. Transmission won't seperate from engine
  13. Recommended Oil type for 2007 F150
  14. Annoying, but not life-threatening (hopefully). Help?
  15. wet msd coil
  16. Number 4 coil keeps going out...
  17. Engine squeal
  18. lightning tuner needed
  19. Cleaning MAF
  20. Lack of power! NHSTA Recall #15932
  21. Spark Plug part nums '99 4.6 w/plug wires
  22. low vacuum, rich condition 5.8 efi
  23. This is becoming annoying
  24. gasket kit for my build
  25. *Poll* What octane GAS 87/89/91/93
  26. Need Help! Cylinder 6 misfire! 5.4L
  27. Noise after truck turns off
  28. compression ?
  29. P0141 heater circuit malfunction
  30. stripped spark plug hole
  31. ford engine guys>help??
  32. 04 F150 FIPK just installed CHECK ENG HELP
  33. Iac?
  34. Timing pointer
  35. high rpm sound
  36. manifold
  37. manifold
  38. HELLPPP!!!!!! F150 5.4L Cyclinder 4 Misfire
  39. Changing oil pressure sensor
  40. Water in COL for Cylinder 4
  41. Plz Help
  42. 04 up plug porcelin removal?
  43. accel coil packs?
  44. '02 4.2L hesitation
  45. Nowhere else to put this???
  46. Antifreeze..
  47. Just replaced Injectors
  48. I finally cleaned my TB!!!
  49. Need Help Please 1998 F150 4.2 engine
  50. sputtering
  51. throttle body spacer?
  52. Throwing code P0232.
  53. Location of fuel pressure regulator ?????
  54. 1000 rpm idle, and it jumps up and down???
  55. Need Help Code 171- 174
  56. I found a turbo diesel in an F-150
  57. Burping Sound in intake tube?
  58. troyer ignition upgrade vs.motorcraft
  59. PCV Removal
  60. 1997 4.2L Misfire
  61. 1990 F150 6in lift 35 ground hawg, 302V8
  62. Help!!! Spark Plug Stuck Or Cross-threaded!!!
  63. Locking gas caps for a 2000
  64. Buy 5w-20 in bulk?
  65. 4.6L Ignition
  66. PI Heads Swap
  67. 4.6 L upgrades
  68. Engine Skipping
  69. 2v to 3v 4.6 head swap
  70. Bigger fuel injectors w/ 4.9L?
  71. Oil Has Changed
  72. know of any injection compatible fuel cells
  73. Synthetic fact or fiction
  74. why change the coils?
  75. Successful 5.4L Plug Change - 1999 90K miles
  76. engine codes bad gas miliage
  77. Romeo or Windsor
  78. 4.6 2600rpm change
  79. Mobil clean 5000
  80. Intake coolant leak
  81. ticking sound
  82. oil....
  83. Does a K&N series 77 intake make my 5.4 run lean?
  84. Spark Plugs and wires
  85. 1991 f-150 runs fine then sometimes won't run at all
  86. 98 f150 help!!!!
  87. 90 deg oil filter adapter
  88. Wtf??
  89. plug change now missssssssssssssss????
  90. Harder to start in the morning.
  91. Gas Mileage
  92. Diagnosis/Remedy from Ford dealer sound right?
  93. remove check engne light
  94. aluminum shreddings in the engine
  95. Dual Oil Filters??
  96. Truck shuttering
  97. fuel sending unit Please Help new one reads E
  98. 4.2 v6 engine swap
  99. major hesitation
  100. how many 05 5.4L have had injector problems??
  101. 2000 F150 4.6
  102. 60,000 mile tune-up
  103. 5.4L supercrew kingranch gas mileage?
  104. Throttle Body Spacer
  105. What's up w/ the Powerstroke
  106. high mileage oil
  107. New to F150
  108. What's the best tuner or chip for 2006 5.4....
  109. Hard to start and P0301 and P0316
  110. spark plug change 2002 4.2 v6
  111. Need HELP....4.6L
  112. 2001 Ford F150 Engine
  113. Best Low end Torque Cam for 96 PI 4.6L
  114. Fuel filter do's and donts
  115. Need intake manifold gasket part numbers...
  116. Is fuel injection cleaner nessesary?
  117. I forget. (4six tick)
  118. Intake manifold
  119. fuel cell
  120. dirty injectors?
  121. rear end?
  122. starting problems need help
  123. Factory Remote filter oil line leaking...
  124. tune up?
  125. Problems with error code readers
  126. Why we shouldnt replace O2
  127. bad noise from my rods....
  128. installing COP - crossthreaded head
  129. motor slowly turning over
  130. 1997 Battery cable hook up help -QUICKLY!!
  131. computer problem (misfire) maybe edge need help
  132. throttle delay on 04(5.4)
  133. 2002 5.4 fuel
  134. 1985 f-150 help
  135. 4.6 PI heads on 5.4?
  136. Thud coming from A/C system I think
  137. SCrew Oilfilter Adaptor
  138. 87 302 in Place of 94?
  139. PO401 code
  140. FordTech1 and Quintin........
  141. shift down when let off gas???
  142. 5.4L spark plug change - warm or cold engine
  143. serpentine belt squeel
  144. starter problems with my 97 5.4
  145. Help!
  146. Mis fire only when engine is under load
  147. Lucas oil?
  148. cam bearing install
  149. 5.4L spark plug change - penetrating lubricant options
  150. Plug removal question?
  151. More Power????
  152. coolant flush
  153. Some help finding something online??
  154. 5.4L Dimensions?
  155. 2v pi heads Romeo vs Windsor
  156. '97 F150 4.6l VIN6 (Windsor) timing question
  157. air bag code27?
  158. best fuel filter
  159. MAF senser
  160. Cam phaser's
  161. 2004 ford F150 won't start
  162. 2009 F150 5.4L Power Increase
  163. Octane booster...how much is too much?
  164. How hard to replace COPs?
  165. 05 f150 loss of throttle control!!
  166. project mini monster underway.
  167. 4.2 v6 swap to 351 t bird motor? help
  168. Percentage of Ford's sales 4.6 vs. 5.4
  169. Burning Oil
  170. Engine coolant temperature sensor
  171. battery light on under hard accelleration/towing
  172. po171 po174
  173. plasma booster?
  174. Important Question
  175. Thank You F150online.com
  176. I have a 12 bolt rear end, is this common?
  177. It won't shut off!!
  178. Intermittent oil pressure loss. help!
  179. 2000 Expedition 4.6L to 5.4L Swap
  180. Inserting picture with signature??? HELP
  181. Maintenance Intervals
  182. Code 172
  183. 5.4 oil leak headgasket
  184. Coolant
  185. Please Help, EEC 4 Problems
  186. Help
  187. Part # for Fuel Filter
  188. PCM Compatability??
  189. SMOKE?!!! That can't be good
  190. cam ?
  191. Plug Wire Poll
  192. i think i got it figured out..sorry for the book
  193. Backfir3, Missfir3 ??? please help*
  194. Spark plug gap
  195. Just an idea (for now)
  196. K&N Air Filters vs. cold air intake
  197. Shuttering
  198. performance camshaft
  199. new performance intake manifold
  200. 06 Engine Surge -18k miles
  201. My Slow 4.6
  202. 4.6 swap 98 f150 to 98 crown vic
  203. looking for pic of 05 5.4L engine bay
  204. 4.6L Got enough Juice?
  205. Good place to mount efan controllers
  206. 04 5.4 3V running on 4 cylinders
  207. Raptor05121 Oil Change Video - The Public Demands It!
  208. Coil Test
  209. Got a problem, pulled CEL codes
  210. Need Help troubleshooting with my 98 fuel system
  211. 5.4L Missing then....OMG!
  212. Successful Plug Change-5.4 3V
  213. 5.4 Block
  214. truck problems
  215. Do you think I need to replace my o2 sensors?
  216. 4.6l
  217. Changing Sparkplugs
  218. Front Fender
  219. iac restrictor
  220. does anybody know how to change oil?
  221. Home Made CAI
  222. 5.4 liter engine is GOOD!!
  223. opininon on sparkplugs wanted
  224. oil at 50k?
  225. Factory Engine Specs
  226. Strange vibration/surge
  227. Replacing Fuel sending unit
  228. Should I remove plugs for Antiseize?
  229. Changed Spark Plugs Now Have Winding Noise
  230. older truck ? power steering over heating
  231. Oil warning light
  232. missing
  233. Throttle body
  234. new intake manifold/heads
  235. NGK Spark Plugs
  236. 2001 f150 5.4l stalling
  237. Do 5.4L engines Use oil
  238. 5.4 engine surge
  239. Motor Gasket ?
  240. Oil Question
  241. 5.4 Using Oil
  242. 2000 F150 5.4L Cylinder 3 Misfire error code
  243. Intake Gasket
  244. No throttle!
  245. Problem Reading OBD "Communication Error"
  246. Best Oil Filter for 2006 5.4L
  247. Ticking sound from 5.4
  248. Supercharge my 97 4.6 Cheapest and best
  249. When did FX4 start?
  250. Puzzling Problem 2001 F150
