my 1998 f150 will not start someone please help
Old Jan 18, 2014 | 10:56 PM
johnnie16's Avatar
OK so I have a 98f150 4.6l 2wd and when I went to go start it one morning I just get this clicking noise so I figured might be starte,or solenoid or batt cables so I replaced them and still get nothing but a click and when I turn key some dash lights go out and radio and interior lite dims off when turn to start position I've tried jumping solenoid and it does nothing and I've connected a jumper to starter and when it makes loud whiny noise like not engaging or something please if anyone has any answers I'm all ears as I can't afford to call mechanic
Old Jan 19, 2014 | 12:10 AM
jgger's Avatar
Have your battery load tested. It sounds like it isn't up to full power.
Old Jan 19, 2014 | 12:16 AM
johnnie16's Avatar
I'm pretty sure my battery is charged I will go check and see voltage with multimeter right now ty for help *** I am so not having fun with this truck
Old Jan 19, 2014 | 12:29 AM
jgger's Avatar
Your meter may very well tell you that it is 12 volts just sitting there, it's when you put a load on it that counts. Take a reading, then try to stars it a couple of times and then check the voltage again. My guess is it will be a bit lower the second time.
You can have it tested at many auto parts stores, just make sure you load test it.
Have you tried jumping it with another vehicle?
Old Jan 19, 2014 | 12:38 AM
johnnie16's Avatar
K so I just tested it seems to have good voltage and there's power going to starter and that lil wirebon solenoid has power when turn key its really weird cuz when I jump solenoid I get nothing but a click and if hold key the solenoid just like buzzes and I've ran a jump cable from pos (+) on bat' to starter and tried jumping but it just whines out and don't crank over truck I'm so out of ideas on this
Old Jan 19, 2014 | 12:40 AM
johnnie16's Avatar
I've tried jumping it with a quick start battery jumper and still nothing
Old Jan 19, 2014 | 12:45 AM
masseyman's Avatar
What ALL exactly did you replace?
Old Jan 19, 2014 | 01:06 AM
johnnie16's Avatar
I've replaced the starter,solenoid and positive and ground wires from battery to solenoid and starter I've not a clue now as to wats wrong was running when parked but now all I get is just a clicking noise much help is needed thank u
Old Jan 19, 2014 | 02:10 AM
masseyman's Avatar
Are both posts on the battery shiny clean and the cables clamp good and tight? What about the ground connections leading off the negative battery terminal, shiny clean and tight?
There's always a chance the battery is bad no matter how it tests. It sounds like you may have gotten a bad replacement starter, but it should still spin by hitting the starter switch, so that isn't your entire problem.
Old Jan 19, 2014 | 03:14 AM
johnnie16's Avatar
Is there any fuses or fuse relays under hood that could effect that I'm not to machanicy but I'm going to take starter out and test it again and see if bendex slides if anybody has any other thoughts would be greatly appreciated and I've shines up all contacts for electrical as well as put new wiring in for bat ands starter and such but I will decently go threw it again cause I am so stumped on this truck
Old Jan 19, 2014 | 04:37 AM
masseyman's Avatar
There is a relay on the firewall not far from the battery, a lot of times this is called a solenoid. Maybe you also replaced this also, calling it a solenoid. I will call it a relay so were on the same page.
When you turn the key to start the relay gets a signal through that small wire on the top of the relay. that sends a signal to connect to the smaller double connection wire on the relay to send a signal down to the small terminal on the starter solenoid located on top of the starter. That sets the starter in motion.
That's the way it's supposed to work. If you could trace the path and see where it's failing. With a test light or multi meter.
Old Jan 19, 2014 | 10:06 AM
Pull the battery, take it to the parts store, get it charged and load tested.
Old Jan 19, 2014 | 02:03 PM
jbrew's Avatar
Easier to just jump the relay. That will narrow the problem down in the circuit to before or after the relay.
Turn the key to run and jam a big screwdriver in between the relay posts.
What happens? Did it start?
Old Jan 19, 2014 | 03:16 PM
johnnie16's Avatar
Oh kl so is There supposed to be two lil wires on solenoid I only see the small wire on the small top post of solenoid and there's no other wire on bottom is it suppose to be like that
Old Jan 19, 2014 | 03:17 PM
johnnie16's Avatar
I've tried jumpoin relay and nothing happens just clicks
