5.4 3v COPS
5.4 3v COPS
ok, problem started with a misfire and not throwing any codes, would have minor roughness while driving but would be real bad stumble around 40-48 mph at around 800 rpm but smooth out a bit around 1500 rpm
newer plugs only 6 months old
drove around with code reader plugged in for 2 weeks and finally captured a pending code for #5 misfire
pulled plug and it's good, changed COP and things ran good
now problem is starting again and no codes again
problem started after brother in law filled it and added "at the pump "fuel system cleaner.
should I start looking at injectors or change all the COPs first
How many miles? at the pump fuel injector cleaners would be I'm assuming just the stuff the refinery adds like techron safe. driving around with a code reader attached isnt going to help you. You need a scanner capable of scanning for live missfire counts or mode 6. Probably a coil they tend to cascade fail one after another and thats why most of us think its just easier to replace them all when they start to fail.
ordered all new COPs, plugs are new but will inspect them as I change the cops
thanks for the help, will update
also- is there a way to replace the retainer clip (blue part) for the fuel filter, the local shop changed it and I got the " oh, did you know this was broke" line. ya right !!!
https://www.f150online.com/forums/20...ight=blue+clip
https://www.f150online.com/forums/20...stupid-me.html
https://www.f150online.com/forums/ar...el-filter.html
https://www.f150online.com/forums/ar...-pictures.html
What brand you getting?
Sounds like accel. Unless they can get motorcraft. But you would know the price would be pretty high. You are more then likely gonna have to change those COPs again when they go bad in a week.
I did mention for you to get motorcraft or visteon from the beginning.
ya but budget is very limited and they do have a 12 month warranty - just say_n
they only had 3 anyway, so I left the one I changed already in place (#5) and changed 3 more, thought about going by firing order but ended up changing the front of eng (1,2, and 6)since they were the easiest to get to and weather was changing very fast and time was running out.the only one out of firing order was #1 I think.
also tightened all mounting screws on all COPs thinking grounding problems.
studder / misfire is gone, just being patient for "the return"
I will change everything out this summer including the injectors as money becomes more fluid
And "just saying" is number one annoying pet peeve for me haha
