when i give my truck gas it dies
hey you guys im new to this forum so any help would be great! i have a 1991 f150 302 v8 5.0 1/2 p/u 4wd EFI and when it starts it takes a few cranks. after it starts, it idles really bad then dies unless i give it gas. i have replaced the fuel filter , air filter, oil filter, oil, all fuses, oil sensor, battery, and i had the gas tank cleaned. fuel pump on the back tank is burned out. front tank works fine but still dies when i give it gas . and when i am driving it wont get past 10mph. and slows down and sputters then when i let go of the gas the sputter stops and it will go back to 10 mph. i took all the spark plugs out and checked them . they were all original plugs . every gap was different between the 8 of them so im am gonna get new spark plugs. would the spark plugs cause it to not go faster than 10mph? if not what else could it be . thanks so much ahead of time.
