- 1st-2nd clunking: Normal, Clutch or Syncros??
- yellow sticker on trans with tsb# 00-16?????
- E4OD trans to C6
- Stuck in park...
- Gear Ratios
- Transmission is Crap
- Vibration in drivetrain
- Speed sensor wire
- Tranny gone at 44,000 miles!! Engine seized at 36,000 What the hell is going on?
- B&M Shift Plus
- what tranny in xpedition?
- 4R70W tranny upgrade
- 5 speed shift issue-please help
- Erratic Shifting
- GEARS
- 94 Explorer Limited Trans.
- Bauman shift kit question
- Horsepower loss for 5-spd and auto
- Factory_Tech... I got a question.
- slave cylinder
- my first 5-sp failure
- tranny gasket
- Lost my tranny!
- Did you get the right auxiliary transmission cooler?
- Anyone replaced the shift knob?
- Front Drive Shaft Broke in 2.
- Uh oh.......
- Is it a transmission cooler? Larger size?
- Noise by flywheel
- Shortening throw on shifter
- Mercon vs. Mercon V
- Truck moves on it's own.
- Shifter or knob rotating?
- found out why my o/d light was flashing
- O/D Light won't stop flashing!!!!
- Tranny Shop You Can Trust, DFW Area?
- Bad Behavior When Downshifting Under Heavy Load
- 2001 Screw transmission cooler question?
- Transmission vibration
- Swapout of open diff for limited slip
- how to tell which Trans I have
- Factory_Tech - How is ATF pumped to radiator/cooler?
- Help, Confused about the overdrive?
- 4X4 Problem?
- Delay going into D&OD
- 98 jerking into drive
- please help
- transmission clunking/chuncking
- O/D Light Freaking Me Out!
- High pitch grinding sound
- Question for GAH--AT temp guage
- Transmission Failure
- Transgo shift Kit 4r100
- What tranny in '99 4x4?
- manual trans question
- Torque Converter
- Crawl Ratios?
- Trans Shudder while Towing?? Help!
- Slipping Tranny!
- Grinding 5 Speed...
- Torque Converter
- Perma Cool trans cooler with fan? - Neal the HP Freak!!
- Attn: Factory Tech - Mercon V in 4R100
- 4R70W 4 WD trans.pan ?????
- Aftermarket clutch recommendations?
- 1997 F-150 5-speed problems!
- synthetic fluids ?????
- HELP
- e4od woes
- Should I drain the torque converter?
- Engine Braking --> Please Help Me!
- Tranny/Torque Converter Problem?
- wheels and tires
- Draining the torque converter
- Breather Manual 5 speed
- 5spd and Expedition center console possible!
- Faulty 2001 4r100 trannies?
- VSS gear location
- Trans temp
- Question for GAH or ? Tranny temp guage install
- THE H.P FREAK FINALLY BROKE SOMETHING!
- transmission cooler question
- Buzzing in Trans When Key Off
- swapping c-6 w/overdrive
- Trans. cooloer fittings?????
- F-150 TRANSMISSION TROUBLE
- Cooling fan on trans cooler anyone?
- 1991 F150 E4OD
- E4OD shift selenoids
- E4OD problems
- O/D Button
- Shift RPM?
- Baumann Kit Instructions
- Synthetic fluid from factory?
- B&M Shift Improver Kit
- '86 F-150 auto tran downshift
- Transmission lags from take off
- short throw...anything new?
- The difference between the Lightning tranny and the one for the Reg F-150?
- O/D Light Blinking / 452 Speed Sensor Problem
- automatic transmission linkage
- very hard shift out of overdrive
- 4.6 / 3.08 / 5 Speed
- Lost 1st & 2nd gears on 5spd man.
- Ready for a good laugh at my expense???
- Occasionally sticks in first gear?!
- How many quarts????
- crazy about f150 ---- question
- clutch problem?
- B&M Shift Improver install and now OH NO!
- Trans Kit
- Overdrive towing with tow package ?
- 452 speed sensor problem
- Transmission filter
- More 5speed troubles
- which gears to use? anyone know?
- What's the best aftermarket cooler for a 4R70W?
- Has anyone done the "Jerry Mod" from the Thunderbird site to their 4R70W? n/m
- reusable tranny gasket
- Auto Transmission cooler?
- Shifter knob
- Trans. Clunking
- 4R70W- output of coolers goes to?
- Just got my 2nd Reman Transmission for my 94 F150
- Trans cooler w/o flaring
- Draining the fluid out of the TC
- Tranny Replacement on 86 F-150
- transmission slipping from second to third
- Dealer tranny "flush" and refill
- Bubbles
- 5-speed shifter removal
- Baumann Shift Kit Installed
- Clicking noise in gear train when downshifting (axle??)
- 4 Wheel Drive low won't disengage...this sucks
- What did I do wrong?
- why 3:73 gears on 1999 and 3:55 on 2001?
- Synthetic in manual
- Supercrew Tranny Clunk
- Growling ZF 5 speed
- Transmission not shifting out of second?
- SONNAX VALVE PROBLEM
- Squeaky Clutch
- Hesitation when hitting the gas.
- Dealership cant find problem to cold engine shudder?
- Calling Factory Tech!
- Clutch Advice
- How many qts does a 97 automatic F150 4.6 take?
- OPINIONS on Baumann vs. Transgo vs. B&M shift kits
- Mobil 1 fluid change
- Odometer stopped counting
- Does the overdrive switch do more than just turn off the overdrive?
- Tranny Dipstick Tube
- Speed - O - Gearing
- Tranny fluid change questions
- Torque Convertor Lockup
- 5 speed shifting problems. Need opinions...
- Questions- Transmission Temp. Guage and Tranny Solenoid Prob.
- Sequential Gear Box
- F250 5.4 Transmission--1998 Question with identifying...
- Speedometer Cable
- Short Throw Shifter
- Need Info on my new ride.
- e40d vs 4r70w
- My Tranny is Toast !!!!!!!!!!!
- TransGo install
- no bauman shift kit -- yet
- no shift kit available yet
- tranny question??
- Is my Tranny Toast
- Rebuilt Tranny?
- BAUGMANN KIT?
- B&M Shiftplus Kit
- Vibration
- 5 Speed VS. Automatic
- towing in overdrive, automatic transmission
- what is wrong with my tranny? ford is checking it out now
- Torque converter - How do I drain?
- Trans Shudder
- Old problem - finally a weird solution - trans shuuder
- Which Transmission is in 2001 4x4 F150 ?
- Checking trans fluid level?
- Tranny Shifting issues
- DOWNSHIFT @ 55TO60 MPH
- Refilling Torque Converter
- Fluid change tips & tricks, synthetic v. regular
- Vibration/Rattle from Tranny Pan
- B&M Shift Kit
- tranny oil change
- 2001 expedition. Does 4.6 litre have 4R70 or 4R100 Tranny?
- Does anyone know
- WARANTY INFO???????????????
- Downshifting "clicks"
- Does a 3.8 mustang trany fit 4.2
- Rear Main seal>>Dropping the tranny
- What Tranny Designation?
- "Shudder" - 2001 SCrew/5.4/2wd
- Transmission flush without filter change ???
- Shift Kit
- shudder at 40-45
- Anyone drain a 4R100 for synthetic?
- Beating A Dead House?
- clutch bleeding problem
- HAS ANYONE HAD THIS LEAK ON THEIR 4R70-W?
- Squishy sound in clutch pedal
- O/D light flashed for a few minutes then stopped
- Is an auxiliary transmission cooler needed?
- Dragging sensation
- Trans Module for a 4R70E
- A slight shudder on my 2001. Under 200 miles
- Question for V10 Man or anybody else that can help
- Shudder in stop/go traffic
- downshifting auto trans
- Trans noise
- Automatic shifts hard?
- Milage
- Transmission Screech
- ? for BigBunnell
- COMMENT AND QUESTION
- Trans fluid???
- O/D on or off for city driving???
- Synthetic in differential's?
- What happened to my tranny?
- y2k 7700 4x4
- cobra R tranny
- B&M Shift plus
- Why is reverse gear so fast?
- Do you know what it is??
- diff. gasket?
- anyone changed to a performance torque converter
- Whinning transmission
- transmission trouble
- Which chain for tranny flush?
- Bleeding Clutch Hydrolics
- Which is better?
- Problem in rear end
- Warranty, when does it end on drivetrain?
- flushing auto trans
- Calling -"eph1fifty"-
- flushing
- Tranny Type?
- I've been censored!
- O/D Light
- Problems with 4r70 auto tranny?
- Hey Cigarxtc
- Wire in my rear end?
- What clutch to use???
- trans removal problem
- Rear end gear #?
