Tranny slipping in first gear
"P0755 Shift Solenoid B Malfunction"
If you drop your tranny pan, you will see the 2 shift solenoids attached to the valve body. It's actually a solenoid pack that has both solenoids attached to a metal bracket. Disconnect the electrical connector and remove the 2 bolts that hold the solenoid pack on to the valve body and remove and replace with the new one. Quite easy!!
