Stripped tranny pan threads!
Old Apr 11, 2005 | 09:39 AM
mg175150's Avatar
I was doing a tranny fluid change to my 1999 F150 5.4 V8 this weekend and managed to slightly strip a few of the pan bolt threads. The cast aluminum is bound to strip at some point. Anway, has this happened to anybody and what did you do to fix it. I guess I can either try some helicoil or a threaded insert, or even tap a new larger thread. There's probably not much room for a bigger thread though.
Old Apr 11, 2005 | 10:27 AM
casey_1's Avatar
Heli-coil is the best way to fix it. They are available at most auto parts stores.
Old Apr 11, 2005 | 06:10 PM
Bluegrass's Avatar
You need to learn some light touch and feel, when a bolt is not going in as it should, unless you like fixing things that are not broke, to begin with..
Old Apr 11, 2005 | 06:31 PM
mg175150's Avatar
Obviously things can't be fixed until they are broke. Unfortunately sometimes they do break. That's life.
Old Apr 14, 2005 | 09:37 AM
carF150's Avatar
I stripped one on mine and just left it. I check it occasionally for leaks and have never had any.
Old Apr 14, 2005 | 11:01 AM
bigred5.0L's Avatar
Me too carF150 Mine is fine as well
Old Apr 14, 2005 | 06:50 PM
zapster's Avatar
as a master machinist.. helicoils are a good alternative to drilling and tapping oversize...but i believe the pan bolts are metric...get the RIGHT set-up and avoid problems like "this bolt goes here..that bolt goes there" etc.. do it right the first time...and drill and tap the hole straight...zap!
