What Color is Royal Purple Transmission Fluid
Old Mar 24, 2005 | 02:13 PM
Rob_02Lightning's Avatar
Stupid question if it's purple
But friend of mine just bought and found his fluid a
dark platium color (greyish)
No trans prob's, seems to work perfect, but a concern
ANYONE ???
Old Mar 24, 2005 | 02:24 PM
01 XLT Sport's Avatar
Purple
Old Mar 24, 2005 | 02:59 PM
tlfwatch's Avatar
??ROB ON YOU NEW MOTOR WHAT WEIGHT AND BRAND DO YOU PLAN ON USEING
Rob on you new motor what weight and brand of oil do you intend to use. do most builders say that 5-30 is to heavy thanks
Old Mar 24, 2005 | 03:55 PM
fast1's Avatar
Originally posted by 01 XLT Sport
Purple
I know when you open a new bottle, its purple. Maybe the color changes after it's been used
Old Mar 24, 2005 | 03:59 PM
fast1's Avatar
Re: ??ROB ON YOU NEW MOTOR WHAT WEIGHT AND BRAND DO YOU PLAN ON USEING
I believe Robs running 15w40 Delo.
Old Mar 24, 2005 | 07:39 PM
Now it's actually a NON Lighting
(to tell you the truth it's a Cheby) (eek)
I knew you wouldn't answer me if I told you that, hehehehe
It's a good friend of Mine, and a worthy truck
(some of my L Bro's have seen it at the Bald Hill Car Shows)
Got a niiiiiiiiiiiiiice Target Motor, Alum Heads, bla bla bla
Poor guy had a little head leak, took it apart and decided to pull the Motor and trans to clean the compartment up, (he's a car show nut) and happen to check the trans oil to find a very strange color ???
So he asked me if there was anything I knew of that WASN'T the normal Redish color, says it smells fine, shifts fine, etc....
Weird .....
Here's some pic's of it
He did use the work metallic look : o () "YIKES" could be bad ???
THANKS.....
Old Mar 24, 2005 | 07:45 PM
Hey wait a minute, I thought it was an automatic
Sure looks like a Clutch Pedal and Shifter to me, what the hell is he talking about ???
