transmission fluid change question
I am getting ready to change my transmission fluid by dropping the pan and also draining the torque converter on my 1997 4.6L Scab 4X4 95xxx miles. I bought this truck used so I am not sure what fluid is in there currently, but was wondering which I should replace it with. Mercon or Mercon V? Also, if I change it over to Mercon V, will any fluid trapped in the cooler harm the Mercon V if the original fluid was plain Mercon? I have heard you aren't supposed to mix them and wasn't sure. Also, any brand preferred for these transmissions over another? Thanks in advance.
Kurt
Kurt
It tells you on the dip stick what fluid to use.
Do the pan and filter job, drain the convertor, fill the pan with about 6 ot 8 qts, then remove the return line start the engine and let it pump into a container untill you see the clean fluid come out while keeping the pan filled with enough fluid.
This will be the best way to tell that you have all the old fluid out but can waist a quart or two.
I have no drain plug in my convertor and have to do it this way.
The local trans shop also does it this way where they have to.
