Transmission Fluid
Old Mar 23, 2005 | 08:11 AM
DaWG of Indpls's Avatar
Lightbulb Transmission Fluid
Recently I was reading a posting from cliles55 regarding transmission fluid.
I have 134,000 miles on my 2000 Lariat. I have had the transmission fluid changed three times in its lifetime. Recently, I have experienced some sluggish feeling in my transmission.
cliles55 wrote that we should be careful not to use anything other than what is printed in the owners manual. Mercon V
If the repair shop I use used a different fluid could that be the reason for my sluggish transmission? If I go back to Mercon V will the transmission react/operate like it should? Is there something else I should be focusing on? Are there tests that I can do to determine if the transmission is beginning to fail?
Thanks in advance for your input.
DaWG of Indpls
Old Mar 24, 2005 | 03:34 PM
seemlessstate's Avatar
well if they used the wrong fluid that could be the problem, id flush ot and replace the fluid ust to be safe, and replacing fluid never hurts anyway
Old Mar 24, 2005 | 07:38 PM
cliles55's Avatar
Dawg,
Read the last reply on this link:
https://www.f150online.com/forums/sh...light=mercon+v
I would bring my truck back to the shop that serviced it with the wrong fluid, if I knew that to be true, and inform them that I expect the fluid to be changed at no-cost (complete change - pan, cooler if installed, and torque converter) and that any future failure will be attributed to their negligence.
You can find some other threads that talk to Mercon vs Mercon V and, as I recall, what some of the effects can be.
Good luck, sorry for your misfortune, and I hope things work out to your benefit.
Curt
Old Mar 25, 2005 | 09:42 AM
Curt
So if I change the fluid immediately, will I be able to tell a difference, OR is the damage already done and the new/correct fluid will stop any further damage, OR am I destined to having a new/rebuilt transmission. Give me a little help here. I have been driving for 40 years and have never had any kind of transmission problems.
DaWG
Old Mar 27, 2005 | 06:54 PM
cliles55's Avatar
DaWG,
I'm not a trans. expert, a consumer like yourself that expects quality customer service. Whether your trans. is damaged, I can't tell you; you would have to bring it to a reputable trans. shop if problems persist.
Did the shop that did the fluid change do anything about servicing with the wrong fluid? I would really press the "quality customer service" issue.
