5 speed tranny fluid
I want to change the fluid in my 98 five speed tranny. What do i use. I want to use redline products because i have heard good things about them but i dont know whats in my tranny, ATF, gear oil, 80/90? i have no idea and i cant seem to find out. Thanks
Fill it with GM syncromesh fluid. It is a fully synthetic fluid that works absolutely perfect in these transmissions. I have been using it in mine for 150,000 miles of pure abuse. Also it is considerably cheaper than most of the alternatives.
Alan
Alan
Ask your parts store for GM syncromesh. Tell them it goes in an S-10 or something like that. I believe it was supposed to be used in the "getrag" transmissions found in S-10's with 4.3 liter engines and fullsize pickups. I don't know the weight on it.
Alan
Alan
I have been running Redline MTL 1 part and redline ATF 2 parts for just under a year now. I had run pure MTl for a few months when the tranny chipped some teeth on the input shaft. The replacement rranny got Mobile 1 Synthetic ATF for 1000 miles then I went to the MTL/ATF mix. I am due for an oil change so I will try the GM stuff. How does it do in the cold? I mean 10-20° below 0°.
JMC
JMC
JMC
JMC
yet another google search
After reading this thread, I found this. Maybe it'll save some people some money, although I personally don't have a preference of any one brand....
http://www.stealth316.com/2-pennzoil-synchromesh.htm
If this helps great. I have an M5OD tranny I my 88 F-150 for the first 50K miles it never seemed to shift correctly, It was suggested that I dump and replace the tranny fluid with Mobil 1 synthetic 5W/30. since that time I have put more than 200K on it with yearly tranny fluid changes of the same with no complaints at all with performance
