Slipping from 1st-2nd and Code 1730
Old Apr 4, 2005 | 10:04 AM
jj1807's Avatar
I sometimes get a blinking light on the shifter (not always) so I took the truck to a shop and they said it is slipping between first and second and has a code of 1730. The truck has 96k miles. Is there any possibility this problem could go away with a filter and fluid change? Does anyone know anything about the code 1730?
This truck has a 4.6 engine with auto & 4x4.
Thanks.
Old Apr 4, 2005 | 01:20 PM
casey_1's Avatar
Could it be P1731? P1730 isn't a valid code, but P1731 means a 1-2 shift error. That means that the computer has detected that the shift from 1-2 takes longer than it should.
New fluid and filter might help, but not likely. It's more likely that there is a broken accumulator spring. That is not hard or expensive to change. There is at least one thread running here that addresses that repair.
Old Apr 4, 2005 | 02:42 PM
dye7barrel's Avatar
Here is the link for the broken 1-2 accumulator spring repair. There is a great article posted about the simple repair which is worth checking out.
