View Full Version : V8 Engines
- 2001 Lightning Engine Knock
- Stock Cobra Supercharger on my truck?
- New Engine feels tight
- Bypassing the AC pump...what do I have to do.
- 93 5.0
- More Power for my 4.6
- Fuel Selector Valve
- Interchanging throttle body & injectors
- Engine will not crank when hot on 1998 F-150 4.6L
- rough idle
- Factory Download
- Idle sucks HELP!!!
- Holes drilled around air filter intake box?
- ATI Procharger For the 5.4 Triton
- Runaway throttle, Over rev 01 SCrew
- 4.9L Missing
- power steering killing engine
- 1762 undocumented code
- Need a 5.4L engine!!!!
- used f150
- Intake leak?
- which cylinder is #4?
- Running nitrous in the expedition this week how big of a shot is safe?
- Will those of you with "real" oil pressure gauges
- closed cooling system
- Check This Mpg Out!!!!!!!!!
- 2003 4.6L oil change
- CV boot torn and leaking
- oil pressure drop?
- Bad Fuel Mileage 4.9
- Oil pressure gauge install
- CODES P1400, P1401, P0401 or P0402
- Power Steering Whine 2003
- 4.6 Gase Mileage
- Torque curves
- Clattering
- 5.4L Performance Buildup
- Service Engine light....confused?
- Pulleys.......which ones
- Serpantine Belt
- Noisy FIPK !
- K & N on an '03 S-Crew
- Temp gauge is pegged
- 5.4L Check Engine
- engine cleaning
- lightning engine
- Check your IAT Sensor Orientation
- Miss/backfire on startup, then goes away. Help!
- Throttle cable snapped??
- Want to make 94 f-150 FASTER
- 5.4L Idle problem
- Plugs/Wires/Coil Installation in DFW
- 4.6 stroker?
- THANK YOU... Please READ!!!
- 1990 5.0 Ho
- Changing plugs 5.4
- can someone explain this code to me
- 97 4.2 Engine idle
- 4.9L Engine Upgrade
- Need help choosing new f150
- Emissions warranty question
- cold air intake
- Ignition Coil 1997 Expedition 5.4L
- ethanol??
- gas mileage... 17.2 mpg hwy... any comparisons?
- Need 2nd opinion on starter problem
- diesel replacement engine
- I have a leak, need some help please!
- Harley-Davison
- No Fuel Pumps ...only during Cranking..Help!
- soot in the tail pipe
- 1997 4.2L E250 Ford Engine Probs
- What kind of HP?
- Melting spark plugs in # 8 cylinder
- Is there such thing as break-in oil?
- Dodge Kills Them All!
- 4.6 stuck valve???
- 03 red lightning
- 2000 california warranty specs
- 4 Bad Coils At The Same Time????
- F-250 u-joints?
- V10 1/4 Mile
- Check engine light.....NEED HELP.....ran diagnostic..
- K&N air filter
- timing chain
- 98 Expd. 5.4 loss of power towing-Help
- california emissions warranty
- Underdrive Pulley Belt?
- dealer trying to shaft me
- '95 Bronco Timing Advance- ***HELP***
- Power Pullies and Water Pump.
- What's wrong with Dexcool for F150?
- Anybody ever tested a coil pack for function?
- What is the effect of sustained boost on a s/c engine? (long post)
- piston slap question?
- Unidentified Equipment
- 4.6 V8 running rough
- F-150 died while driving
- Missing oil ?
- P0455 and P0401
- Intermittent 300 6 cyl
- Lean condition on a 96 windstar
- help!!!!!!!!!!11
- oil pressure drops at high rpm
- I sure hate to say this but....
- Having problems with my Tracer....need help.
- do they make an intake for my ranger
- Real life cost of ownership...
- Need Help!!!
- need more torque out of a 4.6
- Hesitation!!!
- Radiator Flush
- Question about FIPK mod?
- Do these times sound right?
- Fuel Pump
- ebay intake opinions...
- 4.6L Rough Idle
- OIL oil OIl, sigh, growl, vomit
- Yet another oil question...
- 4.6 L V8 Reputation And A Question?
- Boneyard parts 4 mass air convert?
- Need help quick on Oil ? - Please
- Does the K&N fipk work on the 4.6 V8?
- Heater Core on 99 F150
- Oil Filters
- OBD Scantool
- Oil Change Question - 5.4 Engine
- ford power in mercedes
- need some help on a 4.6
- BBK air intake????
- Fan clutch? How tight should it be when cold?
- No start, 5.4L.......
- Still want comment on the 4.0l V6
- F150.com
- Thanks F150.com
- synthectic oil and oil additive question
- My favorite Ford
- Dumb Question.
- horsepower increase?
- Larger Gas Tank?
- Advice on engine swap needed.
- Question about intake air options...
- Throttle Body Spacer
- Oil Consumption
- I'm new. Need intake advice!!!
- Where to buy a 5.4 Long Block
- engine noise
- 351W in a 2002 F-150??
- Royal Purple synthetic, Comments?
- How many are in the 200,000 mile club?
- Best place (price) to get Mobil1 Oil and Filter
- What Next?
- Need your opinions on noise please
- Oil Light coming on
- door rust
- Air filter mod
- ford vs. chevy
- died 3 times this morn on way to work
- '97 5.0 swap
- Powerdyne S/Cer question for a 5.4
- 5.4 vs Lightning
- Can't solve EGR (P0401) problem
- 1991 f150 stalls at take off
- 5.4 spark plugs
- Oil analysis question:
- Coil problem?
- oil viscosity
- 2000 Expedition 4.6 idle searching
- 1983 F150 Thermostat Location
- Mobil 1 0W-20 Analysis
- head gasket concern
- F150 Pcm
- intake HUM/WHINING (LOUD)
- Streetsmart Design Intake??
- sparkplug & wire choices
- building a 5.4 monster ?
- Losing coolant, can't find any leaks
- To Cut Or Not To Cut
- Battery Light Flashing
- 5.4 possible PCM woes
- blown spark plugs
- First post-need help
- Please Help!
- rough idle and even worse at 20-40 mph
- How do you check a injector?
- Supercharger
- Engine won't crank - sometimes
- Oil additives in new trucks?
- Race: Got Whipped :( Wanna win next time
- 5.4 plug replacement tips
- Harmonic Balancer
- Restore Automotive Products
- no start problem help!!
- duel tanks
- surging
- 4.6 hesitation when cold
- Cold air intake, filter digs into hood insulation?
- air diverter valve?
- water in my front diff
- Fuel Cell
- Screching noise at start up????
- Multiple Thanks
- Ignition Problems
- Lack of power/engine noise
- F25o Super Duty Problem
- ignition switch bad?
- Anybody broke a timing chain on a 4.6L?
- How do you program the key ?
- '82 F150 Engine swap
- Cyl 4 misfire
- Anything wrong with using 10w40 oil?
- Computer Code on my f-150
- 5w20again
- Got Nitrous?
- intake noise
- Help With Idle
- 4.6L Performance ????
- my pinging 5.4 cured?????
- Oil change pnuematic pump
- Need to look up some part numbers
- truck wouldn't start
- Lightning Rebuild
- help for an old guy.
- High Altitude
- Sometimes it hesitates, sometimes it dies
- Carbon Build up
- Testing '97 F-150 4.6L Oxygen Sensors
- synthetic oil manufacturers
- HELP!! Fan clutch went out
- What Do You Get For a "Tune-up"
- tb spacer
- Starter stays on after key off
- Wix oil filters
- Resetting Computer after Upgrades & Mods??
- aftermarket throttle bodies
- Synthetic 5w-40?
- anyone considering.....
- 4.6L runs rough @ idle & coast - after tune-up!
- Pulled my 2 codes.....
- Mass air flow sensors
- Feel soft off the line
- Gasoline smell while driving
- 5.4 starts but immediately stalls ???
- synthetic vs dino in low miles truck
- what's the difference?
- 18,000 MILES: not a single problem
