Serpantine Belt
Serpantine Belt
Hey everyone, got a 99F150 with a real bad serpentine belt squeak. Actually, had an updated one put in under warranty a few years ago. Will the belt spray work or will it make it worse like it did on my dad's truck??? Any ideas here? or should I just get buy a new one from Ford ($60)??? Thanks!!!
So both belts squeaked badly? Well, if it is the belt itself, try a Gatorback, they are supposed to be great. It'll cost you a few bucks more than the Ford one, but I'm told it is well worth it.
But, you're describing two belts being squeaky in a relatively new truck. Are you sure it is the belt itslef, or do you think maybe the tensioner or a pulley is to blame? You may want to investigate that before dropping a new belt in. I believe Ford says the belts should last somewhere around 60,000 miles. Good luck!
Yup, get the gatorback. I too had went to the dealer and had my belt replaced under warranty only to have it start squeeling a few months later. However, since I installed my gatorback I have never had this problem again, even after my valvebody install!
-Brian
-Brian
I just bought my Gatorback a few days ago.... go see Mike Troyer (Superchips distributor) at:
http://www.troyerperformance.com/cgi...alogno=4080990
Gatorback is only $35 + shipping....
If you don't want to wait for shipping and such, most AutoZone stores carry the Gatorback belt for our trucks.
Just be sure to check your existing belt and get the proper number of ribs on the replacement (6 or 8).
I paid $45 for it at AutoZone when I put my shiftkit in.
battery light flickers after changing serpentine belt
We are trying to figure out why the battery would flicker, not all the time, just when you idle and hold the break or when you put on the heater- last night it was right around 9 on the meter, but this morning it was totally charged.. do we have too big of a belt, or is our alternator going bad? Please help, please help fast!! Thank you!
