2000 Expedition 4.6 idle searching
I have a 2000 Expedition with 4.6L and 52,000 miles. It seems that the idle searches between 700 and 1000 with the a/c on. With the a/c off it idles at 700 with no searching. I am suspecting the IAC valve but I don't want to pay 100 dollars for the dealership evaulation when the part is 125 dollars. The a/c operates normally. This is my first post so any help would be appreciated.
You ever changed the fuel filter? Cleaned injectors? With the way most PCM's keep track of things I would suggest a weak spray pattern from the injectors.
Or maybe the air needs charging. seeking is a result of clutch kicking in and out frequently. Usually means low charge.
Hope this helps
tom
Hope this helps
tom
Surging
I'm not so sure that it may be mechanical. I had the idle surge with my A/C on and off. I had to take my truck in because the CE light came on because of the fuel mixture being rich. They reprogrammed the computer and that corrected the surge . However, if my A/C is on, guess what. . . I bounce between 700 and 1K rpms when I come to a stop.
