power steering killing engine
Old Aug 31, 2003 | 06:54 PM
J15BIG's Avatar
i have a 1998 explorer with the SOHC 4.0. sometimes if i lock the wheel the engines RPMs drop soo much that the car shuts off. i was making a u-turn and it shut off. does anyone know why this is.
Old Sep 1, 2003 | 01:12 AM
Pestco1's Avatar
The power steering puts a load on the engine that the IAC is supposed to over come by increasing the RPM. Check your IAC to see that it is not plugged up w/debris and that it moves freely. I am sure that some other things can cause this but that is the easiest to check and the most probable
Old Sep 1, 2003 | 12:51 PM
Xplorer's Avatar
Does it stall when turning the wheel and sitting still or only when moving and turning(making u-turn etc)? Do you have any other idle/performance concerns(hesitations, low power etc)?
Old Sep 4, 2003 | 12:25 AM
J15BIG's Avatar
at idle too. if i just lock the wheel, sometimes it dies.
Old Sep 7, 2003 | 12:49 AM
KYFordFreak's Avatar
I know on our 97and up F150's there is a pressure sensor that compensates for the PS and it's not the IAC. Not sure of the proper name, I'll try to find it later.
Old Sep 7, 2003 | 11:41 PM
864Lightning's Avatar
Alot of EFI systems have a pressure switch on the powersteering pump or box that tells the computer that the steering is being moved , so at idle the computer will boost the engine speed via the IAC.
A faulty switch or a dirty IAC could be the problem, but you said it was dieing at lock.. Could this be a faulty pressure relief valve in the steering box? When you are at lock it isnt relieving the pressure and causing the pump to kill the engine..
I have never seen that happen but I guess it is possible..
Good luck with your problem..
