View Full Version : V-6 Engine
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17
  1. v6 to v8
  2. Whats wrong? Truck 'jumping' after shifts...
  3. Size MAF?
  4. v6 a knocking
  5. changing the oil
  6. Coolant leak on '97 F-150
  7. Worst Service Ever. Ready to switch
  8. v6 air intake same as v8 ???
  9. Cant Get The Fuel Filter Off!!
  10. Just got my F150
  11. Heat shield update
  12. Problems with chip?
  13. MAF Carve Q's
  14. Engine Missing,Coil Problem,Need Help Please
  15. Alternator question
  16. Pcv Valve Replace When ??
  17. Ram Air?
  18. misfire after jba headers install
  19. Supercab roof leak.Any tips on pulling the headliner w/o trashing it appreciat.ed
  20. 4.2L Crank
  21. Coolant Leak on 4.2 1997 F150
  22. Calling All with Intake Gasket Leak
  23. rear seal
  24. dropped V6, different shim degree?
  25. gears
  26. gas fumes between cab/bed .No visilble leaks,everrythig dry.Ever happen to you?
  27. Fuel Filter Question
  28. How much oil.
  29. 4.2 overheat
  30. The dreaded squeak...
  31. Pulley
  32. My engine bit the dust....
  33. Is this an improvement?
  34. '98 4.2L spark plug wrench size ??
  35. Check engine light and MAF sensor
  36. rear main seal
  37. Roller Rockers
  38. Heat shield vibration
  39. 4.2 chip and computer location
  40. V6 EGR Location
  41. Where do I start?
  42. oil leak
  43. Milestone
  44. Lower Head gaskets??
  45. Operating temp of
  46. Timming
  47. Are there any performance packages for 4.2L?
  48. Throttle Body Spacer
  49. start up noise
  50. What will it look like? Hmmmm!
  51. Anyone with Ranger/Bronco II experience! Help me
  52. Built 4.2L =334 rwhp and 340 rwtq
  53. Flowmaster 50 price?
  54. towing with a V6
  55. Exhaust advice
  56. installing a vacuum gauge
  57. v-6 ignition coil
  58. V6 Performance Upgrades
  59. Stop truck, idle stays at 2000rpm
  60. What to do, What to do?
  61. Upper/Lower Intake and Head work
  62. confused
  63. Factory warranty question
  64. how fast are your 4.2Lz?
  65. Headers!
  66. Differential/Gears
  67. Underdrive Pulleys
  68. Clearing codes!
  69. Tensioner removal question
  70. found a good 98 4.2l....
  71. muffler question
  72. Friends 93 I-6
  73. crate motor won't "catch"
  74. Uneven Plug Wear On V6
  75. Clutch/tranny??
  76. Pulleys for 4.2
  77. had to kill
  78. P0133 slow response
  79. Ticking
  80. Oil Grades
  81. Me too!
  82. Straight Pipe or Flows?
  83. Warranty question
  84. K&N causing check engine light to come on.
  85. The dreaded knock
  86. F150 Fuel Mileage Update
  87. Annoying Rattle, Whats it from?
  88. Air Intake Kit For 4.2L F150???
  89. Anyone running nitrous?
  90. Question about engine replacement
  91. Newbie + MAF size ??
  92. Need better speed/acceleration in 4.2L...
  93. Fuel filter chnage
  94. timing chain cover
  95. Plug Wires for 2001
  96. I fixed my 97's leaking gasket!
  97. New Engine (?)
  98. Larger Throttle Body? Help performance?
  99. Strut Tower Bar/Rear Sway Bar
  100. Any 97-98 4.2 L problems?
  101. Beefy 2.9 EFI?!?
  102. 2002 4.2 Ext Cab Lift Questions
  103. My latest gas millage...... Running rich??
  104. Do V6 F150s have an 8.8 rear?
  105. Please tell me your horror stories about your 97 4.2L engines
  106. Everyone Please Call Ford
  107. V6 Timeslip page!
  108. Anybody Used This On Their 4.2L ?
  109. How to get more power out of a V6 F150
  110. What Just Happened?!?!?!?!?
  111. start up of V6
  112. v6 idle speed?
  113. someone please help me
  114. Castrol Syntec 5W-30
  115. No More V6
  116. please help!
  117. Poor Mileage - PLEASE HELP!
  118. Oil level?
  119. Limited Slip Question
  120. My slow coolant loss not thr dreaded timing gasket but even more obnoxiouis
  121. to v-6 or not to v-6
  122. Graduating
  123. Octane of Gas
  124. think i've been making a mistake!!
  125. engine change
  126. GAS GUESTION. again
  127. 4.2 Cam...
  128. Changing out a 4.2
  129. Front Main Seal Leak (help)!!!!
  130. 4.2s not rebuildable?
  131. Gas Mileage
  132. Tachometer and redline
  133. Changing the oil
  134. 01 4.2L help
  135. HELP!!! 1999 will not START!!!!!!
  136. dont know what to do!!
  137. I got a new truck...I got a new truck...I got a new truck...I got a new truck
  138. 4x4 lightning
  139. spark plug change (Help)!!!
  140. spark plug change HELP!!!!
  141. replace 97 4.2l
  142. headers and exhaust
  143. Trade in my 01?
  144. Code Readers
  145. It's almost time...
  146. Oil Change - Help
  147. Door Ajar?
  148. v-6 supercharger
  149. front valence fabr...
  150. Which mod is better?
  151. Transmission issues
  152. Horsepower
  153. fair price for my truck??
  154. Should I get this?
  155. gallery
  156. Major Gas Mileage Problem
  157. Horrible Gas Mileage!! help!!
  158. Camshaft Position (CMP) Sensor
  159. Waranty on cats!!!
  160. Rough idle
  161. Breather Element
  162. AjRagno,YOU THE MAN!
  163. leaking coolant
  164. Cheapest place to buy an airaid?
  165. Stumbling 4.2 V6
  166. Campshaft Syncronizer
  167. Does this seem ridiculous?
  168. Accident
  169. Gibson Supertruck Exhaust
  170. intake manifold
  171. 4.56 Installed - ?
  172. Water Wetter?
  173. Spark plugs, need your knowledge
  174. Plug gap for Platniums?
  175. My 97 4.2L Started Leaking Today!!!
  176. Coolant color.
  177. Got the 1999 xl w/4.2-5sp
  178. High flow cats?
  179. Well, I had my windows tinted...
  180. fixing lower intake
  181. Filter and Intake
  182. What needs to be done to my 4.2?
  183. For Sale!! :(
  184. Are all the 4.2 V6 engines bad?
  185. Timing Question for engine experts
  186. Wheel bearings
  187. code p1518
  188. Flowmaster on V6
  189. MIL eliminator
  190. What oil is best for a short-trip vehicle?
  191. Help!!!!
  192. Yeah!
  193. How do you decode engine build date?
  194. 98 Explorer 4.2 build date 2/98 engine problems??
  195. Question on replacing the valve lifters.
  196. tornado, and brand of cool air intake??
  197. Looking for link
  198. 4.2 Intake Gaskets causing bent rods
  199. Fuel Injector wire insulation melted
  200. Cat Back Exhaust Question
  201. modifying a 4.0 v6 ranger - help with gearing please
  202. Will a 4x4 valence fit on a 4x2 bumper?
  203. NEXT TRUCK WILL BE 4x4
  204. What do you do for better performance & speed after intake, exhaust, and chip?
  205. I need help with 4.2L Spark Knock
  206. oil Question
  207. 4.2 Tach Switch
  208. Grrrrrrrrrr Stupid Intake!
  209. How often should the fuel filter be changed?
  210. Slight miss
  211. Obo>?>
  212. Resale Value on 4.2 V6 Auto?
  213. Trouble codes
  214. 4.2L Poor MPG
  215. 4.2 Engine Mod's!
  216. New Rebuilt 4.2 engine swap
  217. Need to get rid of!!
  218. Supercharger On A 4.2 V-6
  219. Installing an intake?
  220. Changing Starter
  221. Water Pump
  222. throtle body
  223. Missing, Backfiring, Hesitating V6
  224. Modified Air Intake Pictures
  225. How many miles on your V6? >100k?
  226. Gear change?
  227. Safe Towing?
  228. I just wanna go faster!
  229. Borla Exhaust now for 4.2L V-6!
  230. 97 Coolant smell from exhaust
  231. V6 acceleration and hauling
  232. Finally!! Got it running!
  233. Intake
  234. Aftermarket Spark Plug Wires
  235. 4.2 5-speed Towing
  236. Front wheel bearings
  237. A group purchase?
  238. ford surprised about 4.2
  239. 4.2 throddle body cleaning
  240. 2001 f150 with auto trams
  241. Oil Leak
  242. New rebuilt 4.2 engin
  243. Engine Swap
  244. pcm replacement????
  245. Air Filter Any Good?
  246. Checking/Fixing Starter
  247. Overall Power ??
  248. Piston Ring.. HELP!
  249. I own a 97
  250. Letter from FoMoCo.
