Vibration 4.2 V6 need help
Hi to everyone,
I just got a 1999 Ford F150 XLT with a 4.2 V6 and when I got the truck the motor was seized because it blew intake gasket and coolant got in the motor. I just rebuild the motor changed out all the parts etc.. The motor sounds good now and runs good. I have check everything compression and vaccum etc. everything is great. It has a small vibration around 1100 and 1200 rpm but smooth high end and at idle. The next thing that I have not told is the torque converter it fell when I removed it from the motor and fell on a thick pad and I do not know if that mess up the balance on it please let me know if that is normal or what do you thing it can be thanks.
