02 F-150 Power Stering Pump Help Please!
Old Aug 23, 2007 | 08:54 PM
junktruckman's Avatar
Greetings all,
I hope maybe someone can help me with replacing my power steering pump in my 2002 F-150 4.2L v-6
Pump seized up today and shattered my (plastic) (my 97 I think at least was metal) pulley , I've ordered a new pump and pulley from Nappa and I've removed the old pump so I don't have to worry about core when I get there and it's always good to match it up..
2 questions please
1) how do I get the old burnt fluid out of the system of the truck?
2) There is a specialty Teflon o ring on the high pressure line of the pump and I had a hec of a time with this same o ring on my 97 and had to take it in to finally get it right he said he had to heat up the o-ring but I'm not sure how, hot water, hot air? how can I insure that I put this o-ring on so it won't leak..
and I'm hoping that o-ring comes with the new pump..
any help is appreciated...
Old Aug 24, 2007 | 11:01 AM
What a waste of time..Nobody can help me here...
I'm kind of surprised not one person responded to my questions..
I'm curious why, nobody here knows anything about replacing the power steering pump...???
Geeeze!!!
Old Aug 24, 2007 | 01:53 PM
Stumps's Avatar
Alright if I was in your shoes myself not ever changing a pump on my truck I would go ahead and buy the high pressure line between the pump and steering box that way you will have all new seals on that side.
Drain all the fluid out of the hoses or better yet replace them , I don't believe the steering box holds much fluid but with the hoses off you could turn the box lock to lock and this may expel some of the fluid.
Stumps
Old Aug 24, 2007 | 02:25 PM
BullRing's Avatar
I actually never heard of such a thing.........If it was me I would google what your looking for and see what comes up you might be surprised. Hope evrything works out.
