4.2 Q
Old Sep 4, 2007 | 01:46 AM
JRCheesman3's Avatar
4.2 Q
since i bought my truck after it already had the larger tires and body lift i never actually had a feel for its stock drivablity. with the manual 5 speed what are the maximum speeds while in 3rd, 4th, and 5th gear?
thanks
Old Sep 4, 2007 | 02:43 AM
'06STX's Avatar
I use third for passing anything, and I won't shift into fourth until 75 or 85mph. Thats at like 4k+ rpm, but before the redline. Fourth and fifth will be limited by the speed limiter.
Old Sep 4, 2007 | 09:21 AM
04heritage's Avatar
before tuner
1st- 30
2nd- 55
3rd- 85
4th- 99
with tuner and 200 extra rpms
1st- 35
2nd- 60
3rd- 90
4th- ??? so far 105 just to find out if the limiter got removed with the tuner
Old Sep 4, 2007 | 05:58 PM
1969mach1428's Avatar
Originally Posted by 04heritage
before tuner
1st- 30
2nd- 55
3rd- 85
4th- 99
1st- 35
2nd- 60
3rd- 90
there's no way your truck made it to 85 mph in third. well, is yours 4x4 or 4x2?
Old Sep 4, 2007 | 06:01 PM
thanks
i'm assuming your truck is 4x4, and in that case, here's what i shift at
1st- 25or30
2nd- 45
3rd- MAX 70
4th- limiter will kick in.
Old Sep 5, 2007 | 01:38 AM
With stock tires and 3.55 gears, it should hit 85 in 3rd.
Old Sep 5, 2007 | 03:50 AM
'06STX's Avatar
My speedo will hit 85 in 3rd. I have 275/55/20 tires and wheels, and at those speeds my speedo is like 6mph lower. So mine does over 90mph in third. There's still 4th, and 5th too. I have a 3.55 rearend gear too.
Old Sep 5, 2007 | 09:51 AM
With 3.55's, you really don't want to go much past 80 in 3rd - that's about 5000 rpm.
Old Sep 5, 2007 | 12:56 PM
yeah, my tires aren't quite stock.. neither are my shocks. so wind resistance on mine might be a bit worse. and i also wasnt thinking that my truck isn't calibrated to the tires i have on it, but they're just a little bit taller than stock, and they do make a huge difference at high speeds as far as what the speedo says.
Old Sep 5, 2007 | 12:58 PM
https://www.f150online.com/galleries...cfm?gnum=10370
