anyone have a lifted v6?
Old Jun 25, 2007 | 12:51 PM
bigal13184's Avatar
i have done a 3" lift on my 1997 f150 with the 4.2 and put 35" tires on it. it actually does handle the tires pretty well but gas mileage has suffered. just showing my truck and seeing if anyone else has one simmilar. i am also considering doing a 3" body lift for appearances. i want to add a picture but i cant figure it out. can someone post it for me i will e-mail it to them
Old Jun 25, 2007 | 02:26 PM
ChrisT's Avatar
I put a 6" lift on mine. I have my truck custom tuned by Troyer Performance and put in some 4.56 gears. Truck performes pretty good for a v-6, although at the moment I only have 33" tires.
Your truck looks good man.
Old Jun 25, 2007 | 02:48 PM
BtownFord's Avatar
I had a 4 inch fabtech on my 99 f150 with the 4.2. I ran 285/75/16 inch tires. It looked good but could barely get out of its own way.
Old Jun 30, 2007 | 11:49 PM
clar's Avatar
just droped gears in mine 4.56 now you half to stay off the gas better than stock...
Pics in gallery
06 Step Side V6 4.2L
Procomp 6" 3" Block 2"ADD
Fabtech Duel Steering Stabilizer
35" ProComp Tires 17" Moto Medal Wheels
Air Raid Intake
Flow Master Cat Back 3" 4" Tip
Old Jul 3, 2007 | 03:34 AM
hoya34's Avatar
check my gallery......
Old Jul 17, 2007 | 01:06 PM
jb1999's Avatar
Any effect on transmission shift with lift & gear change
Has anyone had an issue with a hard shift from first to second in their automatic transmission after lifting and a gear change? My 1999 has a 6" RCD lift, 4.56 gears, 35" tires, and XCal II tune. The 4R70W transmission will shift hard from 1-2 unless I really watch and give it very light throttle. The transmission was gone thru at a tranny shop and the 1-2 accumulator spring was replaced, but it still has a noticeable snap/jolt if you start with too much throttle and I do not mean by flooring it or trying to be fast from a stop. I was wondering if this was a result of the gears and tires (size & weight)?
Old Jul 18, 2007 | 09:21 PM
ChrisT's Avatar
Sounds like we have the same set up except tires. I run 33" tires currently. I don't have a hard shift from frist to second but with 33" tires and 4.56 gears my truck shifts from 1st to 2nd pretty quick under normal driving conditions. When you got your tunes done, did you ask for firmer shift points? I remember when I had mine done there was 3 different choices on how aggressive you wanted your shifts to be.
Old Jul 18, 2007 | 10:00 PM
dodge_slayer01's Avatar
3.5" spindle lift, 1.5" spacer, 3" body lift, and 33's
Old Jul 22, 2007 | 01:49 PM
bigal13184's Avatar
finally figured out how to post a pic, this is how it sits now [IMG][/IMG]
Old Jul 23, 2007 | 09:03 PM
atvRiDa400ex's Avatar
not too big of one, but for now its enough
