Mass air flow question
Old Sep 17, 2007 | 11:11 AM
bjmore's Avatar
Angry Mass air flow question
2000 F150 4.2L auto.
I have a mass air flow problem. I am driving with a known bad sensor (wire is physically Broken). IT is not showing any symptoms of a bad sensor.
I bought a used one from a junk yard. Installed in and motor works like crap and dies after majorly stumbling.
It does not make sense if it runs fine with know bad one.
Any thoughts.
Old Sep 17, 2007 | 11:27 AM
MGDfan's Avatar
Any thoughts.
Hi.
Alignment of the planets, maybe?
Anyways - wire that's broken may not be immediately critcal, and the yard sensor may be faulty and/or needs a-cleanin'. Use CRC MAF cleaner only - don't touch the element.
Or , try a KNOWN good sensor. That's 'shootin' 101 lol.
good luck.
bubba
Old Sep 17, 2007 | 11:47 AM
jk007's Avatar
Yes, try cleaning it with CRC (I think that's what it's called). Also, if you are still having problems, I have a spare stock MAF sensor from my 5.4L... I don't know if it will work on the 4.2L but if it does, you're welcome to have it cheap (plus shipping). It is off of an 03 5.4L, I have the entire stock air intake, I upgraded to a K&N. I know for a fact that it works.
You can PM me or just email me @ johnnyhardclose@yahoo.com. I have a paypal account but again, try cleaning yours first. No sense in paying for something you don't need.
Good Luck buddy
Old Sep 17, 2007 | 12:38 PM
bjmore's Avatar
The sensor from the Junk yard has been cleaned. No difference..
Old Sep 17, 2007 | 12:44 PM
MGDfan's Avatar
Well, then ya got it from the right place.
It's junk, alrighty
[BTW - I'm assuming the donor vehicle was the same as yours?]
Go try a brand new one.
bubba
Old Sep 17, 2007 | 12:48 PM
bjmore's Avatar
Yes JUnk,
And it is on its way back to where it came from.
Old Oct 17, 2007 | 06:34 PM
*hammer's Avatar
Yes JUnk,
if a mass air sensor does go bad what are the syptoms.
thanks
Old Oct 17, 2007 | 08:55 PM
jk007's Avatar
thanks
If it's bad, you should trip a CEL. I'd imagine that you truck would run chitty also, sputtering maybe.
I had one that needed to be cleaned, but it wasn't bad. I knew it needed to be cleaned when I would hit the gas and go WOT and the truck would always sputter and and stop before it would finally kick in. All my dash lights would come on also and then go off.
Old Oct 18, 2007 | 12:37 AM
The symptoms of a bad MAF sensor is poor idling/stalling, excess fuel consumption, severe pinging, and definatly a rough running condition.
Old Oct 18, 2007 | 05:21 AM
mitch150's Avatar
Originally Posted by MGDfan
Hi.
good luck.
bubba
Hey MGD, hope you see this. You say to use CRC MAF cleaner only. Is this as opposed to CRC electriclean? Couldn't find the MAF cleaner at the local auto parts store and the other stuff is supposed to be for the same thing. Thanks, hope you reply.
Old Oct 18, 2007 | 08:56 AM
jk007's Avatar
I used CRC Electiclean, it worked great. I don't think they make a special kind for MAFs. You should be good with the standard.
Old Oct 18, 2007 | 09:10 AM
projectSHO89's Avatar
I've used brake parts cleaner for years. Cheap and works fine.
If you unplug the MAF sensor, the computer uses default values in its place. It will run okay, but not at peak efficiency or emissions You will, of course, get a MIL.
Steve
