'96 4x2 Oil Pan Gasket Replacement
Thanks for responding Diesel Brad. I guess I was not very clear before. What I meant was, the oil pan was loose already, but I was unable to remove it from under the engine and above the front axle. I asked a few repair stores and they confirmed that the engine needed to be jacked up (don't forget to remove the engine mount bolts) to give the pan enough clearance. I also did some research on previous post through the SEARCH feature on this site, and it was very helpful. The gasket has been replaced, hopefully no leaks.
Thanks,
Mel
Thanks,
Mel
