- 3.9L Magnum/4.2 Essex/4.3L Vortec?
- Higher octane?
- 230 hp/ 270 ftlbtq v-6
- Is it still SPi?
- I made a mistake and now don't know how to fix it
- PCV Delete
- Bad Gas Milage
- Advice on what I should do next??
- confused?
- confused?
- Some pointers please
- 4.2 v6 Flywheel
- No heat
- Yet another question... finding TDC???
- Low idle?
- Does my 02 need the PCM reprogrammed?
- 2002 4.2L PCV - Drivers side
- '99 F-150 V-6 4.2 with P0174 & P0306
- Replaced many gaskets.
- Wheel bearing installation...need advice and pointers!!!!
- increase mpg's
- Anyone Know Where I Can Find An Engine?
- Aftermarket Fan?
- Intake Manifold Gaskets: Need Some Advice
- spark plug replacement
- once again i need help
- Asking for help one more time.
- 97 4.2 with codes PO 1132 & 1152 and a lot of black smoke....
- Noticeable gains?
- ENgine Problems need help aSaP!!
- No Power!
- Changed my Plugs! rrr
- my truck is running like crap
- www.fueleconomy.gov
- Best oil for 4.2L?
- High MAP
- Grinding noise
- where the HECK is that PCV????
- Help!!!! Need A Part Like No Ones Business!!!!
- Need help on a 98 Windstar.... ticking when cold start.
- V6 Engine Buildup...
- 2009 F-150 (read the announcement)
- V6 Stock Exhaust- New Tip Video
- my fuel mileage today was 22.8!! WTF?
- Performance chips for 4.2
- how much could i get for my f150?
- Brother is looking at an 00 F150 V6, Advice?
- Supercharger?
- need a little help
- Get the most out of 4.2
- Yucky Fuel Mileage!
- 97 F150 new 4.2 with stumble
- Installation Help please! Autometer 9118 Magneto Signal Converter
- New V6 and I am back on the road!
- Check Engine Light Lit!!!!
- Tach
- Headers
- weird problem
- Anyone upgrade Ignition on 4.2?
- Horse Power ?
- Power Steering Pulley Play?!?!?!
- 97 4.2 timing cover
- want gear drive
- Installing a new computer?
- optimal tire size for the V6 engine (97-03)
- blown V6
- Humming sound from the front
- 2000 Coolant Leak
- Obdii P1401
- Mac or Gibson Headers?
- Mac or Gibson exhaust?
- Magnaflow or Flowmaster
- Anyone change or fix IMRC on a 98 Windstar?
- 285-75-16 with everything stock need to know??
- Intake gasket
- 4x2 winter traction?
- finally, up and comming upgrades...good...bad?
- Need help on heating/cooling system
- Short Burnout! (Video)
- Lugging in trannie/engine at low power?
- transmission filter change ?
- turbocharging a 4.2 V6
- 4.2 Iac ?
- Ft. Lauderdale to Toronto...fuel mileage
- Hard To Start
- V6 won't turn over
- Better fuel milage?
- '96 4x2 Oil Pan Gasket Replacement
- My truck hates me.
- performance inhancer study that needs verification
- putting truck back on the road
- need advice on the updating process
- 4x4 light
- V6 with Manual Tranny - Final Gear Ratio & Clutch question
- Need Advice On Updates
- changing spark plugs
- mass air flow sensor
- supercharger
- What part is this? (Pic)
- General Consensus on V6 trucks.
- 4.2L Jasper gone bad
- 4.2 dead.
- What kinda transmission do i have
- V6 suddenly running bad
- what type of oil
- 4.2 V6 BAD fuel economy...
- Noisy Fuel Pump-Trouble Code won't clear
- Annoying Squeek When Running
- intake...?
- 1988 F-150 V6 4.9 tow rating
- Slow to turn over
- Time for some upgrades...Need suggestions
- Question on the cost of an IMRC
- Oxygen Sensor removal tips/tricks and voltage specs?
- Lookin at new V6s...need opinions please
- 2k RPM ?
- '98 V6 performance upgrades?
- Loud Knock
- Another "imfamous" P1518 Code question
- did tune up now wont start
- Resistor
- K&N Fuel Injection Performance Kits
- 91 I6 running rough
- best sounding glass pack??
- camshaft synchronizer issue
- 2000 F150 V6 badly misfiring upon acceleration
- Interesting 4.2l Literature
- thinking of buying 97 4.2L 4x4
- idle problem
- Changing Oil FYI
- 300 v6 oil pan gasket
- Gargling V6
- Which exhaust and other upgrades???
- random changing-gears-from-full-stop problem
- Buying a 98 6 cylinder...any good?
- sorry for lack of info
- Found the problem to "Weird Codes"
- it's me again
- Motor question
- Why won't my truck start?
- MPG increase with Troyer Performance Underdrive Pulley!
- 97 4.2 question
- f150 4.2 vs mazada B3000
- Question on Fast Idle on Starup (new "to me" F-150)
- 97 F150 4.2 Rough idle, Shakes/stalls at start sometimes
- Vibration 4.2 V6 need help
- Weird B0260 code on 97 4.2
- What type of exhaust?.....
- Troyer Underdrive Pulley Installed!
- How much for exhaust
- Any one use the Troyer Under Pulley?
- Gas on a 4.2L
- 98 F-150 4.2l
- Pleas help me! I´m in Sweden with problems...
- Mass air flow question
- few 4.2 v6 questions
- gas mileage
- clamp or weld
- gear q??
- Oil pan removal
- 4.2 rattles, tried different things still no fix
- need some ideas
- Let's talk Intakes...
- thrush turbo muffler
- Bye Bye v6 !!!
- 4.2 f150 vs 4.0 v6 frontier
- 2005 4.2 xl engine configuration
- manifold coolant leak
- muffler/no muffler
- Headers or Chip??
- f-150 4.2l to 4.6l swap
- 4.2 Q
- Cam Swap
- What is a good good programmer for a 4.2l?
- 2004 f150 v6 heritage
- 3.8l supercharger on a 4.2?
- motor upgrade
- Very Odd Gas Mileage
- 2006 4.2
- 02 F-150 Power Stering Pump Help Please!
- Where to find mfg date
- No more Hydrolock worries
- Several seconds to start when warm
- A few questions about the V6 F150 i just bought
- 98 vs 2000
- Thinking of buying an '04 F150 Heritage, V6, 4.2L, but it has 130,000 miles...advice?
- Are V 6's OK after 1/15/98
- spark plugs
- new owner
- 1999 V6 Bearings
- Maf
- v6 vs v8
- Squeal from engine with A/C on
- 4.2 Serpentine belt change
- Hesitation with overheating
- Oil Filter
- How Much Lift is Too Much?
- What Exhaust??
- 2 Row Radiator Install
- Question about replacing radiator hoses.
- what is worng
- v6 burnout
- Mileage
- 98 F-150 More Bad News
- What are you guys running for cold air intake on the V6??
- 98 Ford Ranger idle
- Initial oil change
- cam
- Noob
- Ticking noice only when cold
- I'm back after a long time gone
- Cleaning the 07 throttle body
- 4.2l v6 Power Generator
- oil grades
- oil grades
- V6 Ford Challenge Aug 25th, 2007
- 4.2 V6 CEL won't turn off
- CAI for an 07?
- 98 F 150 4.2 White smoke out of exhaust
- 255fuelpump, 42# injectors,90mm maf
- IMRC questions
- Intake manifold question
- Trouble Shifting Manual Tranny 02 4.2 V6 64k miles
- new member w/problems
- 5.4 parts for the V6 or 4.6
- part name
- Increasing Economy?
- oil loss
- I think i need to replace my battery.
- Exhaust Leak - '96 F150 with 300 Straight 6
- Buying a New Truck! Need Help!
- MPG w/33" tires
- 4.2v6 change to 5.4 v8
- possible fix for the hesitation and stumble
- Gold Mine of info for the 4.2(a must read)
- Towing RPMS
- anyone have a lifted v6?
- 4.2L Intake Backfire & Rough Idle
- The sixth plug........
- V-6 Engine (more Power)
- Newbie here haha
- took out speed sensor 97 auto 150
- Engine almost starts then cuts out, not all the time
- Life Expactancy on a V6
- Oil pan removal help
- Is a 2007 STX a "Heritage" model???
- turbo 4.2l
- Pitted intake
- Heistation, stuttering, missing, and popping noise?
