ecoboost doesnt like short trips or being babied
I have been having the fuel dillution oil level rising problem this winter on my 13 ecoboost. The oil level has been up to the bend on the dipstick. I figured i would try an experment before dumping the oil. I drove the truck for a good 15 to 20 min then i did a couple 0 to 60 peddle to the floor runs and let it sit overnight. Checked the oil next morning and it was just below the top dot on the dipstick. Either all the fuel /moisture burned off or it sucked it into the intercooler. Anyways i think these trucks need to be worked and they dont like short trips. Also since redlining the truck it has been running alot better and just feels more peppy probably in my head. If any one else is having this probably before installing catchcan or letting ford tsb your truck try this out, i think this truck needs to be beat every now and then.
I'm sure that it is not in writing.
But every vehicle benefits from hard driving. In fact it's the cheapest tune that you can do. I can't find a link but I believe every vehicle today learns and adapts to the way you drive, this changes shift points and engine tune.
No car likes short trips since the oil doesn't get hot enough to "burn" off the water in it. The difference with a turbo car is there's an intercooler for it to collect in.
The only time my EB had the CAC misfire was after several days of driving around like I had Miss Daisy and a bunch of nuns in the truck when it was cool and damp. The way I see it, Ford spent all that money putting numbers on the tach. I should try to use all of them.
I babied mine for a week or two a while back and it started running like poop.. Kicked it in the *** and got a cloud of black smoke and it took off and been fine since.
Driving like you stole it is the only driving here in Houston. Just would be surprised that a dealer tech would say it.
He is great and tells it like it is. Hell Ford should really pick him up and take him into their development.
There ya go the verdict is out! Drive like you got nuns in and you're truck will run like poop hahahahahaah
Have you seen any of his videos on here? Or on YouTube?
Here's th' vidya - first post in this here thread:
https://www.f150online.com/forums/20...need-know.html
With my oil being up to the bend on the dipstick it is safe to assume that it is dilluted to a lower viscosity. But after running truck hard and having truck return to normal oil levels would the oil return to normal undiluted viscosity? Roadie i have only had this oil in since october and noted the rise within the last 3 weeks, high has been below 32. My oil had strong fuel smell with the rise but since beating on my truck the oil has a faint gas smell along with accetable oil level. My wife thinks i am nuts because i am always outside playing with and smelling my dipstick lol.
