TSB 13-08-01 - Intercooler fix - will it reduce power and/or MPGs?
I got the dreaded engine drowning issue this past weekend - driving for a couple hours in heavy rain and heavy traffic. Stopped at a rest stop, and upon leaving (heavy acceleration on on-ramp) it stumbled miserably.
But I recognized the issue, backed off the gas, and kept on driving. After a few tip-ins over 10 minutes it dried out and ran fine.
But I'd like to get it fixed. I can't imagine what that would feel like if I were pulling my 30' camper.
So I called the dealer and they said they would install TSB 13-08-01 which blocks the air at the bottom of the intercooler.
I assume this is to keep the bottom hotter and therefore vaporize any moisture that might try to collect there?
So my question is - will this make any significant reductions in my power or MPGs???
If the air leaving the intercooler is hotter than it should make less power in theory...
Does anyone have this TSB already - did you notice any difference?
PS - did anyone find this link yet? Interesting read - its the Ford response to NHTSA on this issue
http://www-odi.nhtsa.dot.gov/acms/cs...018-57516P.pdf
so the intercooler is under pressure and this will always be a very slight air leak, right?
Is there any issue with it whistling?
Does anyone have a How-To that shows where to drill the hole?
There's always a little bit of pressure in the intercooler and there's enough other noise to cover a whistle. The "other" F150 Forum has a couple hundred page thread on doing it. There's a couple of how tos there.
The first one is what I was talking about. I don't think the mods like us linking to the other place.
The best place is the elbow on the drivers side at the very bottom. That's the lowest point in the outlet. I haven't done it yet on mine, only because it's only done it twice and I'm busy/lazy.
And its a very small hole that I feel confident I could "make disappear" with a little black RTV if needed.
Hey guys been reading all these threads and I have a question I have a 2014 explorer sport and im.getting that surge also will drilling a hole in my intercooler fix it? The sho guys are saying don't do it it's two different engines bit I have tried everything to fix this surge amd.its not working I am.tuned one step colder plugs and 3 bar map sensor.
question, I got the shutter and drilled the hole yesterday. the drill bit went through the plastic then hit something hard about a 1/16th the way after getting through the outer plastic, bit probably only went in 1/8" total. I can feel air coming out. Do I need to drill to the next layer or leave it? I figure leave it, but nothing came out so want to check
