P0174 is really getting to me!!! Please help
Hi all . Not to post another redundant problem but here goes. 97 4.2l code P0174 only. Have checked all vacuum lines PCV valve & tubes are great. LTFT BANK2 is +25 @ idle and of course drops to normal range while driving. O2 sensor on bank2 is fluctuating normally. Have tried LP to find leak while watching SRTFT and cannot locate . Upper & lower intake manifold gaskets have been replaced. Exhaust manifold is nice and tight to head. Inspected exhaust manifold from top & underneath truck did not see any black areas to indicate exhaust leak. I really am stumped . Any help would be greatly appreciated!
the metal plenum 4.2's has a vac hose under the plenum that is an issue and is easy to overlook when testing, maybe????? I'm shooting in the dark just a little.
Two other odd ball you can get a vac leak is the rocker cover gasket on the PCV side or maybe the IMRC, I believe that is also vac related.
I'm not trying to question your testing abilities, just throwing out some of the more rare causes. The reason I asked about the HVAC control is because some have had issues with the vac lines breaking close to where they go through the firewall and testing under the hood won't show a leak inside the cab.
I hope you find it soon, good luck. If any other stupid stuff pops into my mind I will pass those along also.
No problem. I appreciate any and all suggestions. After thoroughly checking and rechecking yesterday I took the truck out for hard drive back/ forth on the freeway. Pulled into a drive through and while I was in line there was a tick, tick, tick coming from engine. Maybe I have an exhaust leak. I'm gonna pull the manifold on bank2 and inspect because I could not see anything while it was still connected. Hopefully that's my problem. That or a fueling issue to that bank.
