- oil usage
- Break in period?
- Best method on change p/s fluid
- fuel line recall
- 302 warmed up run real ruff cold is fine
- FIPK and catbacks worth it?
- Question on 4.6l heads and intake
- Piston slap
- Engine terms, mods, and tuning for dummies book?
- '97 F-150 check engine light help.
- 1992 2x4 302 to 88 4x4 351 swap
- Does anyone use a valve cover breather?
- Running out of Warranty
- to gas additives really help?
- platinum plugs. 100,000 mile joke
- question for Boss Lariat
- Engine difference
- Belt Tension Pulley on 5.8L ('95)
- Power Pulleys An Jacobs Ignition
- Cause of engine stumble at idle?
- SVO Supercharger
- 460 and 400 model years?
- K&W Trans-X Stop leak and tune-up
- 1997 F150 Rough Idle
- 96 Crown Vic fan installed, kicks rear!
- 100,000.00 Mile Warr.
- swapping a 4.2 V-6 for a 4.6 V-8
- is this possible.....F250 running 15.47 ?
- 2001 5.4l, feels not as powerful?
- 97 f150-coolant in oil
- Flushing, Synthetic, and FILTHY!!!!
- Plugs and wires
- Lightning Heads for a 4.6L
- oil pan trouble
- Clutch
- HEADERS ARE GOOD! Now which one is most beneficial
- 5W30 MOTORCRAFT OIL
- Half dash lights
- Hoppin up a 5.4
- Anybody have dynoed their stock 5.4 F150?
- 1999 Black SVT Lightning & E-Bay 1 Hour Left!
- Need more low end! but how?
- What's up with our engine fans?
- Resetting the Computer
- Please Help
- MotorCraft Oil Filters
- What is the TSB for piston slap in a 97 4.6 taking to dealer to replace motor?
- Truck keeps dieing and won't start back...Help!
- Hi guys new to trucks and I've got some questions about my Roush
- Just curious
- 87 ford f150 won't start
- Who's using AMSOIL HERE??
- Throttle Body Cleaning
- WHY IS THE TRUNK VIBRATING help!!!
- Amsoil By-Pass Filters
- Chip?
- Swaping engins from an 82 to a 86 F150
- Transmission, Differential code.
- oil leak on 4.6, anyone else have this problem?
- I am the REAL METALLIC BLUE!
- Ford told me something about my engine timing.
- Anyone use Costco or Safeway gas?
- You Guy's Are The Greatest! ( 5W-20 Oil)
- About Metallic Blue
- Mobil One 0w-30 or 5w-30
- ah cruize uh nice `64 yoyoyo don't make me shank ya!
- how should i use my Nitrous system
- Mustang GT pulleys on 4.6?
- Fram Air Filters........
- Where can I get performance heads for a '97 4.6L?
- Recieved Vin Number how long for truck to be delivered?
- Lifter is sticking.
- Is this true about synthetic oil?......
- Anyone got a stock airbox they don't need?
- Wal-Mart Oils
- What's this noise?
- What about Mr. TURBO?!?!?!
- ATTN: Ford Is Unaware of the Door Crack TSB.
- plowing
- Question RE: Ford ESP Warranty
- 5W-20 Oil
- 4.6 liter oil burning
- drop in k&n air filter
- VIN Decoder
- switching to amsoil...
- Can I use nitrous on my truck?
- Just ordered Air Force 1 FIPK
- mobil 1 oil filter hard to find?
- mobil 1 oil 2.97 a quart
- 4.6L Water/Coolant Leaking into oil
- What's your favorite Manual?
- This has got me thinking!!!
- We aren't the only ones.............
- recommended services for 20,000 miles?
- Wow!
- old turn style odometer to digital? is this possible
- Oil Weight Discrepancies
- 400hp club
- Cost of synthetic oil vs. dino oil -- What a huge difference!
- Carparts Coupon ??????? # ??????
- Fuel Filter Replacement
- switching to synthetic
- !Help! me install the K&N fipk on my 2001 4.6..
- I think my 5.4L engine blew tonight, 99,000m
- Mobil 1 vs Amsoil
- What's the best chip for 5.4L
- Welcome a newbie, NO AIR FILTER!!!
- Thread Size
- EGR valve explained here!!!
- Is this common or should I be worried?
- Lethal Injection
- Dealer tuneups,why the two prices??
- SuperCHARGER! ahhhh damn now you all have done it..
- Headers?? Are they worth it for that PRICE?! (CHIP?????)
- How do I add my truck info?
- Reseting Computor
- High Idle
- FIPK Systems
- HOTTER INTAKE AIR WITH OPEN FILTER. NOT!!!!
- What's the correct HP for 2001 4.6L V8
- speedometer
- clutch R&R and now it idles rough?
- 2000 5.4l K&N Airfilter on 2001 5.4l?
- Need Tech bulletins for passenger head oil leak
- Pro-M worth the money?
- Alternative to K&N?
- Speed
- Engine hesitation/surge @ 1350 RPM -- SOLVED!!
- Free Mods?????????????
- Magna Charger
- High Altitude Fuel Ratings
- Synthetic Oils
- LEV Sticker
- Clarification on 5W-20 oil issue
- what kind of FIPK
- Switching from Synthetic BACK to Dino Oil
- 87 or 89 Octane?
- 5.4L DOHC Navigator Motor For Sale On Ebay!!!
- 0w30
- Premium gas in a SuperCrew
- Check out hard numbers, Superchip, AirRaid, Gibson SS
- Temperature and pressure ranges in 5.4L?
- what do i need with my eaton M90. someone help with this SC question.
- Poweraid Spacer
- 5.4 vs 6.8
- Damn sparkplug boot.
- I need help finding the engine specfications for a 1993 f150xlt with a 5.0
- Howling/Whistling noise
- 0-60times(Best modifications)
- 4.6 4V motors on eBay!
- Harley Davidson F150, cheap!!!
- better bang for the buck?
- Engine Miss at Part/Mid Throttle
- Engine Upgrades
- Engine Opinions---4.6 vs 5.4
- Magnacharger Warranty ? & Performace ?
- How do I identify the build date of my 5.4???
- Test Drove new 4.6 lariat 2001 my impressions
- Turning Odometer Off
- Cold Start
- 99 f150,any grease fittings ?????
- Navigator 5.4l DOHC engine
- does anyone have a FQR in their 98?
- The Great FQR Rip Off
- 4.9L Hesitation
- To FQR or Not
- K&N Air filter?
- How much $ to run with a Chevy?
- Fan Belt Replacement, Need HElp ASAP
- I want to lose that pinging feeling!
- 4.9L Missing
- Piston Slap Replacement New or FQR?
- Engines
- What size is throttle bodies on 4.6 and 5.4
- Head gasket oil leaks?
- All those w/class III towing, or HD cooling pkg
- Oil Performance Comparison
- New Guy on the Block
- 2001Hypertech PPIII
- FIPK for 2001 5.4L?
- 4.6L with mods ?
- Horspower ratings
- Amsoil & Oil Analysis
- I am curious
- V10 Power Ratings
- Bad sound coming from my engine!
- Oil Drain Valve
- Which oil filter?
- Engine Stall & Rough Idle
- Gibson Dual Sport Truck
- Conversion from a 4.6 to a 5.4
- Starter noise when cold outside???
- 4.6 Cobra Engine
- Thanks to all for input, made my decision
- NEED HELPP ON 4.2
- Oil Leak-Passenger side-How to approach dealer/mechanics.
- Need Ford family advice
- Weird noise
- Is It Ok To Wash Under My Hood With a Hose
- Swaping out a 4.2L for a 5.4L
- 2001 5.4 Engine - Wont Start
- Where/what is the octance shorting bar?
- Crash! or other supercharger experts
- F-150 Diesel engine
- Smell raw fuel??
- ENGINE WONT START
- When will it stop!
- Which engine/truck should I buy?
- Where do i start
- Engine dies, need help.
- oil weight
- should i upgrade to 3.55 from my 3.31?
- 98 4.6 chk engine, rough, hesitation
- airaid intake system
- Engine stalling, need help
- Thanks F150online
- Engine Performance
- Who's the fastest Pro 5.0 racer in NMRA
- Poweraid Spacer Wanted
- Fuel problem, but where?
- out of the shop
- 5.4 -Wins best of breed AGAIN!!
- OIL USAGE -How much is Normal???
- Dodge Dakota's
- EGR Question
- Performance
- Supercharge A Harley Edition
- New FQR Installed - Report
- Horrible Idle surge on 2000 4.6 5 spd
- What kind of oil and filter???
- Hows this sound ? BRAND NEW 2000 F150 4x4 ext cab OffRoad,4.6 $26,000.00
- Milky oil filler cap
- Temp up, Oil pressure down!!!
- 2000 4.6...what is hp and torque?
- Buying a new engine!!?????!!!!????!!
- 5.4L horsepower
- need help w/ engine selection for new truck.
- Electric Fan ?!?
- Hows a 3:31 ratio for towing with a 4.6 Triton
- Dealer would't Put in Bosch +4's?
- Found a Cool Place with some great deals!
- ATTN: All FQR Cases
- how do you install the superchip?
- 5.4L using oil
- 82 mm mass air flow sensor..need input
- Questions for all that switched to synthetic.
- anyone tried the Superchip?
- Belt Squealing Noise
- will a mustang supercharger fit in an f150.
