#1 Cyl spark plug deformation
Old Sep 11, 2004 | 01:10 PM
cliles55's Avatar
99 4.6L Scab, 141k miles, usually run 87 octane with mixed city/hwy miles. Has been regularly serviced.
I've changed plugs for 30 years and have never seen only 1 plug so much different than the others. All 8 electrodes are light tan and show no abnormal wear - except for #1 cylinder. The elctrode is deformed; looks like someone pounded it flat! Any ideas? Could the timing for #1 cylinder have caused this? Can only 1 cylinders be affected without affecting the others?
Old Sep 11, 2004 | 01:26 PM
jimsa2806's Avatar
yikes! Are you sure it was the correct plug? It seems like it was too long , causung the piston to hit it. Did you hear any metalic sound while running those plugs???
Old Sep 11, 2004 | 03:16 PM
cliles55's Avatar
I have heard some pinging lately but I attribute that to garbage gas. I've recently gone back to Chevron and am using 87 octane; it was not noticable when I ran 89 octane garbage gas.
The electrode is still there, has a bend in like it should, but looks like, I don't know, pounded almost flat due to detonation? preignition? wrong timing in that cylinder? I dunno!
I've had the truck 2 months, bought it used with 1 owner who kept it serviced regularly. It did have the original spark plug wires; I should assume the original plugs as well. It runs fine; I was dumbfounded when I pulled the plug out.
I've got digi pics (not great quality). If you want to see them, drop your email.
Old Sep 12, 2004 | 08:52 AM
jimsa2806's Avatar
Well, if the electrode is there, then it's not getting slammed by the piston, which is very good news. The pinging is likely because you're running on 5 cylinders b/c of the bad one. It has to be a problem with that cylinder only--if it was a fuel or ignition problem, it would be system-wide. Maybe a problem with an injector that won't shut off? I don't know, this is now beyond my limited knowledge of cars and engines. I'm sure someone elese here has some ideas.
Old Sep 12, 2004 | 09:33 AM
cliles55's Avatar
Thanks for the reply! I may give the Ford house a call this week unless someone else on the site has an idea.
Old Sep 12, 2004 | 10:59 AM
cliles55's Avatar
Decided to use my head, got out the multimeter and ohm'd out #1 wire. 4.86 on the 20K scale but would vary to 12 or 14+, or even open, when I moved the wire at the sparkplug boot. All other wires, although varied in lengths, did not change resistance noticably when moved/rotated/gyrated at either end.
Must have been the wire. Increases in resistance causes increases in amperage/current flow, right? I'm not an electrician.
Old Sep 12, 2004 | 01:53 PM
jimsa2806's Avatar
wouldn't hurt to start there. Just pull that #1 plug often to keep an eye on it till you know the problem is solved.
Old Sep 12, 2004 | 03:13 PM
cliles55's Avatar
Thanks, jimsa. I appreciate your interest.
