oil drain plug torque???
Old Aug 30, 2004 | 10:21 PM
kn127's Avatar
Does anyone know the torque for the oil drain plug?
Old Aug 30, 2004 | 10:28 PM
JMC's Avatar
JMC
25 Year Member
Nope, I just turn it till it is snug and add 1/8th of a turn.
Regards
Jean Marc Chartier
Old Aug 31, 2004 | 09:55 AM
max mitchell's Avatar
Don't bother torquing it. It's very important not to over-tighten it and strip it out. It should just be snug.
Old Aug 31, 2004 | 06:27 PM
jimsa2806's Avatar
change gasket regularly too
change your oil drain plug gasket (washer) every 2-3 oil changes. If you are posting this because of a drip from the plug, a new gasket will solve it. If it still drips, try a different type, like cork and rubber or nylon, if yours is metal, for instance.
Old Aug 31, 2004 | 09:33 PM
kn127's Avatar
Thanks for the info. No, I am just bad on 'snug'. Love the torque wrench it gives peace of mind.
Old Aug 31, 2004 | 09:48 PM
DCLoppy's Avatar
This is a kind of classic pro and con analysis:
Too loose - a slow leak that is obvious and visible, and correctable
Too tight - a totally f@#$ed up oil pan
THEREFORE - snug, and observe!
Old Sep 1, 2004 | 08:00 AM
JMC's Avatar
JMC
25 Year Member
Ok, if you only feel comfortable with torquing it then the spec is 98-143 in/lbs of torque. I looked it up this morning.
JMC
Old Sep 1, 2004 | 08:51 AM
hcmq's Avatar
Get a fumoto drain valve and will never have to worry about it again!
