302 EFI missing under load
1990, 302 4wd auto EFI
Idle seems OK, engine becomes a little rough when put into gear and misses (bucking might be a good descrition) while under light or heavy load while driving. Basic ignition parts are about 5 months old, I took one good spark plug wire and cycled it into all 8 positions, it made no difference in any position. I also disconnected the spark plug wires one at a time, each one made the truck idle worse. Distributor is clean inside. I replaced the iginition module about 5 months ago, had this one tested today, it failed, got a new one on warentee but the truck stilll runs the same. Had the replacment module tested, it is OK. I looked at a couple of spark plugs, they look great.
I have moved on to fuel now. (Filter is about 5 months old) I listened to all the injectors I could reach, 4 on one side, one on the other. I can hear a distinct clicking in all of them but one. This is on the driver's side, at the rear of the engine. Could this be a problem even though disconnecting the spark plug on this cyclinder made the engine idle rougher?
I would appreciate some help, fuel injectors aren't my thing. Thank-you
more information. After noticing the "non-clicking" injector I checked more spark plugs. The plug at the "non-clicker" is damp, not oily. The other three plugs on that bank have a lean burn look to them. Does this support a bad injector diagnosis. If so, are there fixes other than replacement of the injector.
Also this vehicle always stays outdoors, since it has been sitting in my shop, I notice a slight gasoline odor after it sits for a couple of hours.
This is one heck of a discussion thread I am having by myself. Probelm solved, no further help needed.
The injector was siezed, I checked for electrical pulse, it was there. Next I sprayed wonderstuff into the vent hole in the solenoid body of the injector, waited half an hour then started the engine. Tapped on the injector for a couple of minutes with the truck idling, the truck began idling very smoothly. Kept tapping for another couple of minutes; went for a drive, all seems to be well. This injector now clicks with much more authority than the rest when checked with the stethescope.
If it all blows up, I'll let you know
