dual gas tank problem
Old Sep 20, 2004 | 10:12 AM
seabee570's Avatar
1994 f150, dual tanks,on front tank i am not getting any gas to carb,what should i look for.is there an electric valve for each tank,any help appreciated....thanks
Old Sep 20, 2004 | 04:03 PM
CXI's Avatar
CXI
I have a 1995 dual tank. I'm going to assume the 1994 has a similar dual pump system in the tanks.
Do you know if the tank pump is functioning? From the off position, if you turn the key to run, but not all the way to start, the fuel pump will run to charge the system. You can hear a faint whine if you have the window down. Do you hear that noise when you have the selector set to front?
