DTC Code P0401 Gas Recirculation
Old Sep 22, 2004 | 04:24 AM
crain's Avatar
Question DTC Code P0401 Gas Recirculation
Guys,
Has anyone had DTC Code P0401 to come up after running a diagnostic check? According to the manual I got with my micro turner, the code indicates a problem with "Exhaust Gas Recirculation Flow Insuff Detected." In simple terms, is this a problem with bad gas, 02 sensor, or what? It should not be the fluid filter since I changed it only 3 months ago.
Thanks in advance
Old Sep 22, 2004 | 04:36 AM
Mr_Bentwrench's Avatar
do a search for egr related issuse there is alot of info in it here. most likely need to clean egr passages and change dpfe sensor.
