Emissions P0453 code
Old Sep 14, 2004 | 08:46 PM
fordfan1998's Avatar
I'm getting a P0453 error code my diagnostic tool. I believe it is a problem with the canister purge valve. My chilton manual says it should have an front end impedance of 30-36 ohms. The existing unit had 59 ohms, so i purchased a new unit. However the new unit read 60 ohms. I would like to know what the correct input impedance should be. Also, if it should be about 60 ohms, where else could the problem could be occuring.
Old Sep 15, 2004 | 03:25 AM
turbojoe's Avatar
P0453 isn't a faulty canister purge valve, it's "FTP Sensor high voltage detected". (Fuel Tank Pressure).
It's FTP sensor-related...either wiring (shorts to Vref or signal return or loose/broken/open circuit) or a bad sensor.
The PID is: FTP voltage >4.50v with KOEO or KOER, engine running in any mode = hard fault.
