- The Saga Continues.
- whining in 4 wheel drive
- Would a shift kit fix this?
- tube & fin OR plate style cooler
- 88 F-150 5spd whine
- thunk when accelerating from stop
- Harsh Shifting fixed
- Intermittent harsh upshift
- Just a few more questions...
- Reverse & Low (1 on column) kill my engine
- Transmission shot??
- Rear Axle Lube
- Stranded again !!!!!
- trans slips after 3500 prm all gears ?
- fluid change question
- tranny cooler
- Won't Shift into 1st or Reverse
- transmission cooler install
- my e40d was rebuit but shifts bad
- 4r70w direct clutch
- Now the rear end ???????
- Manual Transmission
- e4od shifting trouble
- Shift Kit jerks nasty
- Yet another trans fluid change question
- No reverse, forward is fine
- Does a 2005 truck w/tow package have T-cooler?
- Blinking OD light
- Need help for E4OD fluid level
- Factory Tech 4R70W valve body
- VSS location
- newbie trans temp question
- Major slippage with '00 screw 4x4 5.4
- Rear end gear ratio question
- neutral switch
- shifter indicator on wrong letter.
- 3rd to 4th short shift
- Where to buy street/strip fully built 4r70w?
- Stuck in WD Low range!
- long pause into drive
- removing tran. cooler from radiator circuit
- Please Help !!!!!!!!!
- Torque Converter Bad - What Else?
- Possible head gasket leak?
- shudder hesitation while in overdrive
- What is the difference?
- external transmission cooler
- Factory Tech plate install ?'s
- Stock Trans cooler
- Blinking OD light and DTC P0750
- Tans Fault
- Clutch Chatter 4.6L
- Slipping outta 3rd gear
- '93 E4OD won't shift when cold
- Am I in trouble?
- I think I figured it out
- Auto Tranny Lost Reverse and Shifting
- Bypassing the radiator.
- noise in rear end or transmission
- 1990 F150 5-speed
- 5 speed for '4 new body
- Transmission Pan Fluid Capacity
- Transmission Fluid Temps...Help
- Help!!! Small Filter in Trans Pan, where does it go??
- Transmission Cooler
- Can AODE/W fit where there was a E40d
- E4OD questions
- Feels like I hit a wall when in reverse... what gives?
- Tranny or rear end problem or both
- Slow to Engage
- 99 Expediton w/ 'LONG' 1-2 shift.
- 2003 fx4 not downshifting too smooth!
- Truck stalls in reverse and 1st gear
- How to identify your transmission
- hurst shifter
- Another tranny fluid change question
- What gears for 35-37" tires for 04 Screw FX4
- Trans randomly pissing in driveway
- Gear Question
- 4r70w shift kit
- Hard shifting trany
- Rubber hose to nowhere
- 01 Transmission "clunking"
- 06 Mark lt shifting in-out of OD towing 7x12 trailer
- Leaky Fittings
- Axle code
- Manual Tcase
- HELP!!! Transfer case stuck in 4x4 LOW
- '01 F150 Trans Leak?
- 4R70W BUILT tansmission problem
- Major 5-speed Problem. Help!!!
- Difficulty shifting in/out of OD
- problems in drive
- 2-3 delayed shift -new cause
- Do I need a torque converter?
- Sporadic rear end vibration/shudder
- 92aod tranny shifts harsh when warm
- How do I lube the throwout bearing?
- O/D light flash, code P0781
- Squealing Sound
- I got tranny slippage too!
- How does fluid circulate through
- How much to swap my gears?
- transmission slippage
- Vibrating/Bogging Down while shifting
- Where is the speed sensor on a 99'F-250 V-10
- AOD vs 4R70W What is the difference?
- Clutch Nightmare!!!!
- 2006 F160 4x4
- F150 Passing Gear
- Random OD Flashing
- 2001 f150 4x4 5.4 doesnt go in park
- Please Share Your Expertise - Lurching on Acceleration(??)
- M50D reverse light switch?
- help i am stuck and my 4wd will not engage
- Fluid Type in 4R70W
- 4R100 Shift cable bad?
- Automatic trans...tight shifts?
- shifting Very hard
- Fluid change
- More Clutch and Tranny probs in my 91 f150
- Driveshaft out of balance...
- Mysterious yellow plug...???
- diagnostic code
- Is a transmission cooler required?
- 1st Tranny change
- Would a 6'x12' U-Haul Toast My Tranny Fluid?
- Royal Purple Sychromesh ATF @ 62k miles?
- Trans Temp Gauge Works Intermittently
- Mysterious tranny leak, need some guidance
- quick question which port to use
- 4r70w ATF change question
- Which gears?
- Tranny Fluid for 97 F150 4.6 V8
- 1st tranny and diff fluid change
- My 4x4 truck is lying to me...
- No 3rd or O/D Gear
- Trans Cooler Recommendations
- Sloppy Shifter
- what is hot?
- Transmission Codes
- Transmission shudder
- Help needed on a '95 PSOM
- Towing with OD or not?
- Tempature sensor for computer
- 97 with 4R70W Slipping
- Can I tow my auto F150 4 wheels down?
- Deep Pan installed.
- Transmisson Troubles
- Only moves when Tcase is engaged..?
- Anyone installed a Jet trans kit
- Best way to bleed a clutch?
- Stuck in park
- Where is the test port?
- 2000 Ford F150---Clutch, Please Help
- trucks like shuttering?
- 4R70W Nasty 1-2 shift!!!!! Need suggestions-please
- 2000 F-150 clutch or manual transmission problem: Tough to Shift from Neutral
- 4r70w
- Bad torque converter
- Tranny Problems Please Help!!!!!!!!
- Transmission Dragging?
- Transmission Down
- What is my Clutch and Tranny Doing?!?!
- M5R2 Shift Fork
- TC shudder
- Will this work on my 1984?
- Hard Shifting
- tranny upgrades
- I was told to use TransX
- Pulling boat out of the water.
- Tq. converter upgrade ?
- OD Slipping
- How much HP will my factory Tranny hold?
- Dextron111
- Safe RPM for stock converter question???
- uh-oh
- alternator bad transmission won't engage
- transmission fluid
- 98 F150 Tranny question (engine stalls when put in Rev or Drive)
- Stuck Tranny!
- F150 automatic transmission problem???
- Overdrive problems...I think
- 03 5.4 FX4 in crumby stop and go traffic
- 2000 F150 OD Slipping
- 97 shift cable
- Reading the sticker codes
- Noise in 3rd gear when cold?
- Simple transfer case question?
- Rebuilt Transmission
- Cost of used auto trans?
- OD light not working
- Good deal on 04 F-150 Supercrew
- '02 FX4 Transmission Rebuild?
- No power
- Need Help
- How do I know if it is the Clutch
- 1999 4R70W - Drain Plug on Torque Convertor?
- Fluid Change or Flush?
- OD Downshift Rattle
- od light flashing
- i kno its a car:(
- Confused...!
- Transmission fluid
- Please Help E4od Shifting Prob
- Will it fit?
- external diagnostic for manual tranny?
- 4WD doesn't work
- Can anyone recommend an aftermarket clutch?
- Manually controlled automatic trans?
- 95 F-150 Manual 5 speed going out
- Fluid *pouring* out
- E40D Question
- Help with manual trans!!
- A different kind of problem.
- False neutral, pops out of 1st - 4r70w
- Should I? (kinda long)
- Hard/harder shift down out of OD ?
- 4R70W Accumulator Piston Installation
- symptoms of tranny going out??
- 01 S/C Transmission Problem
- E4OD Won't Engage
- Question for Tranny Tech: Pump Outlet Screen on 4r70w
- Aamco and Cottman Transmissions to merge
- Stock Tranny Cooler Question
- 5.4 w/ a 5 spd manual?
- downshifiting problem 4r70w 2-1
- 4R70W Problems
- Transmission Bogging down
- 1998 F150 Standard trans not shifting to 4 wheel drive
- optomistic F-150 it "IT ONLY GOES FOWARD"
- E4OD 1-2 Accumulator Spring Replacement
- 2wd to 4wd
- Transmission Flush Advice
- aod or e4od to a 460 carburated car
- Difference b/w 4r70w and 75?
- NO BS Aftermarket transmission
- Manual trans options for a '95?
- Need tranny advice B4 taking truck to shop.
- tranny temp sensor
- I Removed the Shifter in reverse
- no reverse
- 94 F150 clutch specifications?
- Trans Go Shift Kit Instructions
- Oil soaked cluch?
- TCC Soleniod failure
- Electronic OD Switch is goofy
- can't get it out of park
- trans make
- Transmission Cooler fan
