How do you
Old Sep 3, 2009 | 02:11 PM
DMD09's Avatar
How do you
My clutch is starting to have a good bit of "play room"< how do you adjust a clutch in an 97-03 F150 manual?
Old Sep 4, 2009 | 12:39 AM
JMC's Avatar
JMC
25 Year Member
What do you mean by play room? Are you having to press further down on the pedal to disengage the clutch? If yes then the slave cylinder is most likely leaking. Remove the inspection boot on the transmission bellhousing and have a look to see if you can see any oil. Check the oil level in the clutch Master to see if it is low.
