Please help.....i'm beggin ya
New Here......Need help.....BADLY
look I know there are a LOT of threads about this but I can't seem to find one that fits my needs.
I have a 1994 Ford F150 XLT 300Inline 4.9L Sixxer followed by a M5OD-R2 with the 4WD Configuration and it seems to be hung up really bad, between 2 gears or what.
It was clanging and jumping before it went out and when you release the clutch it dies out and lurches even while in neutral.
I don't know what could be causing it but I need to find out.
How do I fix this?
Is it fixable without a rebuild and if it does need rebuilt how hard is it.
None of the transmission shops are giving me any prices we could EVER afford.
I really need the help, I'm out of work till this truck is rolling again.
please help.....I could lose my job, I require a pickup t do this.
Thanks to anyone who can give me some insight to this dilemma and how to fix it.
How do I fix this?
Any chance the stalling out may be related to a vacuum hose?
I agree If its the Mazda 5 speed trans which I think it is , I had the 300 6cyl in my old truck and parked it in the yard when the trans started to whine.. Did you check the trans and see if it is full of gear oil.. Mine was so low on gear oil that it started seizing up on me.. I put 2 quarts of Lucas in it and it helped but it still whined a good bit.. AAMCO transmission told me a rebuild would be around 900.00.. Best of luck... You can always find these transmissions at the junkyard for around 350 to 450 dollars.. But like GLC said you need to pull it...
I will be pulling it, and when I mean hung up I mean even thought the shifter is in NEUTRAL the transmission isn't. like its hung up in 2 gears.
It's trying to go in 2 gears at once (it's in 2 gears at the same time), and that's not possible! (I mean it's not possible for it to move that way) Take JMC's advice and pull the shifter housing cover. Shouldn't have to pull the trans. for that- least I don't think. :o
I'll update as I can.
