2002 maintance?
2002 maintance?
I have a 2002 4.6 f150 4x4 FX4. I am just wanted to look for some tips from you all. It has 91000 miles on it. I got it used 4 years ago think 44755 miles on it. I tow jet-skis in the summer. I am looking to change the front and rear diff. ,tranfer case and maybe my tranmission. I just want to know if it a good thing to wait one the tanny because It never been change before (that I know of)or could I do it??
Randy
Randy
As far as the transmission service, I don't think that is something you can take on yourself. In most cases, a machine (can't think of the name right now) is needed to actually flush all the fluid out before the fluid change.
Some have said if the transmission has high mileage, and has never been flushed, then you might not want to do it as it can break seals and all.
My 2002 5.4 with 4R70W does not have a drain plug on the torque converter so if you try to change the trans fluid yourself, all you can do is take off the trans pan and drain about 5 qts and refill. You can replace the filter if you do this, and clean the pan and magnet. If you want all of the fluid drained, you will have to take it in somewhere. I just went through this not knowing it didn't have the TC drain plug. I'm going to just replace 5 qts at a time more often. Mine has about 75k miles on it. The older models have TC drain plugs and you can drain all of it.
