'94 Manual Problems
'94 Manual Problems
I have a '94 F-150 with a 5-speed tranny with some issues. My initial problem was that I couldn't get it into first from a stop without previously going into second (From a roll it went into first just fine). Soon after I started having trouble getting into reverse without rolling forward a bit first. When the tranny did go into reverse, the gear seemed to get "stuck" and the truck would bog down (as if I had the e-brake on). Most recently, first and second gear have gone out completely so that when I go into them, the truck just acts like it is in neutral. As you can tell, I'm not very familiar with transmissions...anybody have any ideas of what I might be looking at?
By the way, within the past year I had some work done on the tranny which included replacing a worn shifter fork and installing a new clutch.
Thanks.
Thanks.
