MERCON or MERCON V Fluid ?
Old Jul 25, 2009 | 01:18 PM
bbarber275's Avatar
I have a 1997 f150 4x4 with the 4.6 engine with vin code W.I am going to change the tranny fluid and filter.So I reading around about what fluid to use.The dip stick says MERCON only, but now I am reading about a Service Bulletin from Ford to use MERCON V in all trannys now because Mercon is not being produced anymore.Can some one clear this up for me.
Old Jul 25, 2009 | 01:37 PM
FX41's Avatar
Mercon V, just make sure when you read the label on the ATF that it is good for vehicles requiring V.
Old Jul 25, 2009 | 02:19 PM
bbarber275's Avatar
I will be looking for the MotorCraft Version if possible.Looks like MERCON has been discontinued in July 2007 from what I found out.So any MERCON found must have been sitting somewhere for sometime.
Old Jul 28, 2009 | 02:52 PM
OhioLariat's Avatar
I was told that synthetic (Mobil1, for instance) will hold up longer, and run a bit cooler?
Andy
Old Jul 28, 2009 | 06:30 PM
Roadie's Avatar
Mercon V is the best to use. On an ex-Ford trans engineer's (JW) recommedation, I put Mercon V in my 95 Mark VIII's 4R70W and it worked great along with all the other members of the Mark VIII message board.
Old Aug 22, 2009 | 07:37 PM
thesmileyone555's Avatar
life,LIBERTY,and justice for all not just the rich
Old Aug 23, 2009 | 12:12 AM
Galaxy's Avatar
Just use Amsoil ATF and you don't have to worry about using the wrong fluid.
