Transgo Shift Kits
Old Sep 2, 2009 | 02:29 PM
Big Orange's Avatar
Registered User
Question Transgo Shift Kits
I recently replaced my e4ode tranny in my 1997 F150 with over 290,000 miles. I had a transgo shift kit in the original one. I removed all the hardware (springs & valves) and replaced with the stock components prior to the tranny swap. However, I lost the install instructions that tell you where to drill out the holes in the valve body plate and what size each setting was. I had the shift kits set up on the middle (tow) setting. Does anyone have a copy of the directions or template that I can use to modifiy the new tranny?
Old Sep 2, 2009 | 06:47 PM
Darrin Burch's Avatar
If you call TransGo they will email or fax you a copy.
Darrin
