- The lift is underway!
- Anyone running a Crane "Truck-Power" cam?
- Where to put o2 sensor?
- Performance Products
- difference between 87-96 302 and 351
- 390 MPFI-----possible??
- 96 throttle body leak?
- Max hp with speed density?
- Happy Birthday Sprocket!!!
- 5.0L Muffler question. Urgent!
- took my truck swimming
- Specifications
- 360 4 barrell problems
- Changing front end parts
- emissions and cat converters
- oem ford parts cheap
- Best place to buy a winch for a trailer?
- Gears are Awesome!!!
- Truck died..fuel pump?
- Where can I get some brake lines.
- 92 f150 possible ignition problems
- Problem with Brakes
- Side gapping plug's (Chris)
- Would Like to do Tune up for '96 F150
- Lifting my truck!
- 19 lbs Fuel Injector Question ...
- HUG2 Computer code
- Trans gear ratios?
- Switching to 1.7 roller rockers
- Top End Speed
- Clunking
- So much.....
- Just ordered some more parts!
- Gear Q
- '90 4x4 center caps
- "high" low idle
- anyone who knows anything about the M5OD please read
- need some quick tire/rim help
- Code 14/19 14/22.. computer going bad?
- Highflow Cat's for a '96 4.9L
- DRL Removal.
- Engine Miss
- Hey all, new to the F150 Online boards
- Went to the 1/4 mile
- does anybody know?
- 96 Bronco
- Unknown Sensor?
- Temp Swings Revisited
- Gears !!!!!!!
- Goodbye
- 4.9 rocker arms
- shock suggestions
- damn water pump?????
- rotted out radiator support???
- Heat!
- Installed Homemade FIPK!!
- Homemade Code Reader
- Mods need opinions
- Where can I get a gas tank?
- Clutch/Transmission
- DESKTOP DYNO 2000 Engine Analyzing Software
- Lifting and Towing
- I sold it...
- Coil Spring Code Needed
- Motor plates
- Need a 4.0 v6 rebuild!
- Leaking Intake
- Did a little off roading :)
- Champion Vs. Bosch
- Engine Swap
- Got a sweet E-Bay deal
- Blew the tranny
- Ultimate Air Intake Setup
- 1994 F250 Rear diff trouble
- Performance Module
- Selling Bessie...
- Injector????
- Donate you're going to love me! 87-91 Clears!
- Wanted to share in hopes of helping someone
- alignment not making it drive straight - terrible pull
- Buying a Bronco
- I just don't understand...gas mileage?
- Whats goin on?
- thermostat
- Power Steering, what the heck is leaking?
- Stroked 351W or BIG Block?????
- EVP Sensor vs. EGR Travel
- 5.0 headers on a 5.8?
- Are there any options for a locking tailgate for a 95?
- how do I post pix of my truck
- women drivers, no survivers
- '78 F-150 with 429
- Mods - I have made a decision
- powertrain control system, what the....
- f-100 ranger
- need front axle shafts for a 78 1/2 ton
- Got Smoked
- tune up time
- throw-out bearing
- 1.7 roller rockers
- San diego owners
- Is an 87 door glass supposed to fit the 88?
- F.i.p.k Finally Finished
- 95 chrome rear bumper
- New Pics
- 92 f150 4.9 distributor change help
- not again...
- Do pre-1997 F150's shift "hard" ???
- Help me understand my rear end
- Mustang wheels on the truck.
- 302 to 351. Is this a pain?
- MAF sensor
- Stock Wheel Size
- Cams Again
- how much can i tow with the stock bumper?
- Powder Coated My Front Bumper
- Transfer Case
- Edelbrock IAS shocks are in!
- This is what it has come down to..
- How much of a difference
- Raising the truck:
- A/c Switches From Front Air To Defrost By Itself
- hot water thottle body hose
- Brakes vs. Vacuum
- Ground wire???
- Need help
- calling Beastie seat lift question
- Anybody go with a 347?
- Shocks
- Burnout at FTW LA Chapter Meet
- Chilton's online
- Leveling Kits - Qx's
- body lift question
- Oil presure
- Ford Trucks History
- HP and Torque on the 351
- oil pan gasket ???
- Upgrading to a High volume/pressure oil pump???
- Crankcase air filter
- Serious Cruise Control Problem
- Will 3" Body Lift clear 33" tires"
- Sqeeky Leag springs
- Front Speakers for 96 p/u
- I think the ol truck is runnin rich
- Air Assist Front Coil Spings
- Trip Odometer
- Bad plug?
- obd I-II
- Camshafts
- Throttle Bore?
- Water Jacket Filler
- Dyno Numbers :)
- Places to get body panels....
- Almost There
- Radio installation Qx
- Compucam2020/powermax
- Sorry my Pre-97 buds.
- Did a Centurion edition exist for 1996 p/u???
- Brake proption valve
- Whistling brakes
- check engine light killing me
- Transfer Case Question
- Dyno time
- Severe idle surge 88 5.0
- clunk while driving???
- cat-back?
- Attn:
- Polyurethane motor and tranny mounts
- where to get oil tested???
- Y'all are always asking/wondering
- Wow how time flies
- 4x4 front axle info
- New Help Needed ( Parts Related )
- Help please
- clear corner lenses for older trucks?
- need help!!
- Saw something awesome today
- Inline 6 Idles Rough
- 1992 production #'S
- Question for Macgyver
- Wondering what I should do
- Raw Fuel Smell
- power window question
- Cowl's purpose?
- how much?
- I think i need some traction bars
- Clunk in rear end
- Fuel Filter
- 1977 F-150 Engine/Tranny ?'s
- Here is a preveiw of the new wheels and tires.
- Enigne Surging at Low RPMs
- Turbo setups
- Towing Mirrors
- Got it back together
- Hey Fella's and Fella'ets
- Day Light Running Lights
- Woah!!!!!!!!!!!
- 88 F-150 Tranny?
- What is this.....whats it do?
- Attn: PKRWUD
- "Rear-antilocks"
- I think I got ripped off
- Is this a stuck thermostat
- 92 custom f-150
- 1972 f-350 ranger xlt camper special
- my 65
- Body Question
- Rocker arms and cam, no clue what to pick??
- New Member, some newbie questions
- really dumb question
- Lug Pattern of Pre 99 f-250?
- 1988 Tranny?
- MAF conversion for 95 EFI 351??
- Gauge Pod pillar
- Ford 5.0 EFI adjustable idle spacer. Any good?
- had my codes checked today
- wahey, just checkin' in
- Sigh
- What else should I replace?
- What would be better
- Installed My Throttle Body Spacer Today...
- Need Block?
- Stupid POS!
- Help, Need Advise Quick!!
- 351
- Uuuum, sure...
- Got my pulleys in
- What should compression be?
- Need Advice with a couple of issues.
- Which Covers
- Engine cutting out
- Ignition switch stiffffffffffffff
- Fuel tank leakin
- Argh!!!!!!
- got some pulley!
- Cool!
- Bronco update and some questions.
- 302 to 514 engine swap!
- 1995 5.8 Idle Speed
- Which injectors for H.O. motor transplant?
- difficulty starting truck
- Reliability/accuracy of oil pressure gauge in '90 F150
- 4WD Conversion
- Goodbye to my 88 F150
- Anybody running an aftermarket throttle body?
- mpg
- Poor Running (Vac - ACV)
- '86 F-150, will 302 fit where my 300 was?
- More HP
- Thanks
