1967 Ford F150 Long Bed w/1970 302 Engine
Old May 13, 2008 | 11:19 PM
winrawr's Avatar
here is the rundown. about a year ago. was drivingthe truck. all is well. .. when the truck just stalls, no electricity, nothing.
figure itsmaybe a faulty battery cable. ....jcharge the battery. nothing.
then i replace start, alternator, solenoid, volt-meter. nothing
then i replace battery, cables.
now it chugs, but doesn't turnover. used carb spray.
maybe its because its been dead for an extended period. Sparkplug issue?
Old May 14, 2008 | 05:44 PM
Ranger7489's Avatar
Did you check your body to frame grounds?
Old May 14, 2008 | 10:20 PM
winrawr's Avatar
yeah everything that is supposed to be grounded is
Old May 16, 2008 | 12:58 PM
adrianspeeder's Avatar
Everything electrical still dead?
Adrianspeeder
Old May 16, 2008 | 04:27 PM
winrawr's Avatar
yeah i have no idea whats wrong
Old May 18, 2008 | 09:42 AM
Do you have a volt meter?
Check for 12v at the battery first, then keep moving the positive lead downstream till you find the break.
My hunch is a fuse link in the main wiring harness that connects from the battery side of the starter solenoid.
Adrianspeeder
Old May 18, 2008 | 10:50 AM
ycgoat's Avatar
When you say all is dead does that mean fuse block too (lights, horn, radio, fans etc..)?
When you check for voltage make sure you use a good ground reference negative battery post is best, or verify a good body ground with a continuity check.
If check for 12v at starter or starter relay if has one and at fuse block. There are usally two power leads from the battery one large and one small. the small will usualy. have an inline fuse that looks like a rubber sleeve on the wire.
good luck
Old May 18, 2008 | 11:05 AM
ycgoat's Avatar
sounds like battery
