View Full Version : V8 Engines
- problems with new 351
- Fuel filter frequency
- Cold Starts
- Ford GT Engine information
- TERRIBLE Clatter
- check engine light on
- Miss Firing, Sputter, Hesitation
- Sticky Throttle Body, What To Do?
- Better Gas Mileage
- A litte troubleshooting help please?!?!
- 86, 460, Cranks Then Sometimes Starts
- 5.4l Block Heater
- Head Recomendations
- Stumble at 1300-1600 RPM
- Doing your own tune-up on a V6
- Platinum plugs required?
- 50,000 inspection tips
- 2003 Lariat center console addition - also chip
- hooking up a tach to a '98
- Opinions Please!!
- F150 Ignition Problem
- Does anyone have a 5.4l?
- Loosing Coolant
- Loosing Coolant
- Loosing Coolant
- Loosing Coolant
- Where is the fuel pump reset switch for a 2000 F150 5.4l engine?
- 2004 f-150 engine noise
- oil filter relocation
- Has anyone done a step by step on replacing the EGR valve?
- Water in engine
- New tires, need a little motor help
- Odometer Question
- The Engines Black Hole...
- Service engine, code 125
- 98 F150 Failed %CO in VA Emissions Test
- Fuel injection to carburetor
- 351W Stock Hp
- A couple of dumb Q's
- 4.2 V6 gone?
- Whats the best f-150/truck to pull the 351 out of
- Rough Cold Start
- Random / Multiple Cylinder Misfire
- 40 w oil
- Cruise Control not working on a 97 F150 4.6
- 1994 F-150 trade???
- 1998 engine cutting out
- need input from performance buffs
- When to change spark plugs?
- Fx4 with a 4.6?? What Gives?? Please read!
- Seafoam
- Misfiring in aftet wet weather
- Thanks Steve!
- f250 v10
- Fuel Filter tool
- heads up on factory plugs
- Header Install Price
- Truck Specifications
- Belt Shriek after WOT?
- Problems after replacing 4.2L
- ERG Valve Operation?
- 1998 ford f150 4.6l 4x4 engine question
- Idling Problem
- Fixed 86 302, would stall when pulling off from a stop.
- Need performance enhancing advice
- Best Motor?
- WOW, this sucks.....
- 5.4L Engine Backfire
- Positive dealer experience
- Buzzing from top of motor
- Oil pan gasket question
- Ticking Noise From Engine At Idle
- Throttle Body Crud
- Quick 150 Question, Please Read!
- gas mileage
- Tensioner pulley, Ford says I don't have the one that's on my truck, what gives?
- 2003 Stalls
- Your Thoughts On Spark Plugs
- drain hole in muffler??
- IAC Valve Replacement
- paid mechanics
- Cylinder 5 and 7 Misfire Repeatedly
- Surging idle only in Park or N
- Helicoil w/ socket - now guess what!
- Advance Auto Brand
- egr gasket
- V8 to 6 Cyl Engine Swap?
- Blue/White smoke
- 93 F150 5.0 engine miss under light load
- 1700-1900 RPM Drone and Vibration
- E fans
- Code question on 4.6L
- For those of you that like to do this
- 1999 F150 5.4 lower radiator hose?
- Replace Serpentine Belt
- while changing the oil filter....
- Neighborhood Competition
- Changing to Synthetic
- gas mileage has gone to poop
- code 451???
- Missfire
- Best Oil Filter ?
- 4.6l 1 time miss?
- Still got the SES light
- Trouble code P1518
- power mods for the 94 4.9l
- Helix spacers?
- 97 5.4 gas mileage need help
- 1994 E4OD For a 5.8
- 4.6L misses at idle
- Where can I find it
- should spark plug easily thread
- How much HP/TQ can a 5.4 make
- switching engine oil, question
- 98 5.4L Block and crank.
- Leaking fuel from filler tube
- Changing spark plug on 1998 4.6l
- Overdrive on 4.6 V-8
- what is the diff between the 98 and 99 5.4??
- Superchips Microtuner
- Oil consumption?
- Cleaning IAC Quick Q...
- leaking freeze plug?
- Chips???
- what cylinder is #2
- anyone using a tornado ?
- Port/Polish questions...
- Ole Blue appears to have the flu
- hesitation after having truck detailed
- Pulleys & dimming lights?
- Intermittant Overheating...
- Head Gasket "sweating"
- non-F150 problem
- Low Fuel
- Y'all were right.
- Jerking under light load
- Warranty Repair HELP!!
- 5.4 Mileage improvements. Comments?
- 4.6L Power Mods
- pressure in cooling system
- 2003 4.6 Windsor
- ?EGR valve wrench - what size?
- fuel milage and bug shields
- Off Topic
- Humming noise at idle
- Replacing Head Gasket: parts list
- 5.4L Head, whats the skinny? 99up vs 98 back??
- mobil one help mpg?
- Throttle Body failure, fuel contaminated oil?
- E-250 5.4 cold start hesitation / stall
- Engine Kits
- 5.4L question Is it PS?
- Building a 4.6l
- biggest throttle body?
- 97 F150 Slight hesitation under load
- Code P0320 Troubleshooting....
- piston replacement
- Engine Troubles
- putting a diesel into a ranger
- 63k and already a bad oil pump?
- 4.6 engines
- 1987 F150 302 EFI Fuel Pump Failures
- Won't start in Cold?
- overdrive or no overdrive?
- 302 failure
- P1507 Code
- Tick Tick Tick
- Lookin' for a 1990 computer!
- 4.6 power mods
- 97,98 vs 99& newer
- 5.4L VIN Numbers
- engine stall
- Help Po401 Code
- Changing over to Mobil 1 today.
- oil question
- HELP asap!! re:4wheel drive
- Which Spark Plug?
- More Horsepower
- sensor
- Wrong Spark Plug - now what?
- The sweet smell of burning oil...
- What does a burnt valve sound like?
- Starter whine/squeal
- Non-electric fan options?
- Gauges
- Non F150 Ford Question
- High pich whining noise
- Strange stalling problem
- Cooling Fans
- Pulleys and towing?
- Going in for tune-up.....need advice----->
- Cool Collar?
- pulleys
- Engine Clatter
- Replace and/or upgrade fuel injectors?
- P0401 - summary and questions
- Engine Light is on
- 2001 XLT,I diot oil Press gage?
- Code: "Evap Gros Leak" ?????
- Need more horses!
- 4.6L crankshaft
- miss fire #3
- 1.7 RR's?
- When does the F150 get a diesel?
- Oil filter locations (pix, please) OEM or not
- Engine Sounds
- f250 v10
- Help! Antifreeze under intake
- 03 rough idle
- thin oil at change
- Overheating...
- **NEED HELP- 4.6 acting up at 95k
- squealing noise from steering(turning wheel)
- oil leak
- Weird Engine Noise
- Problem Starting expy
- 100mm trottle body?
- Metal grinding sound at any speed???
- cel po133 - help!
- Fluid Help Please
- Sputters and Pings when cold, please help!
- Rattle
- 5.4 turns over, but wont start, bells chime.
- Code P 1635??
- 4.6 throttle body / egr passage cleaning ;Pinging 90% eliminated
- 4.6 specs
- Autolite plugs
- PCV filter clog
- Wont start when hot,engine stall PROBLEM SOLVED
- Anyone installing a lightning block
- It ain't whistling dixie!
- need advise
- Cleaning MAS ??
- Runs terrible when cold, great when hot
- Service Schedule
- Possible IAC????
- now what?
- Mechanic says I got the wrong engine?!?!
- Engine swaps?
- more pinging/timing/egr..
- I hate to ask...but...
- Piston Slap
- Please Help
- pinging
- spark plugs
- EGR Valve
- Gears or Chips
- Aluminum engine
- will it work ???
- 93 F150 302 ping/knock/misfire
