86, 460, Cranks Then Sometimes Starts
86 F350
460 CARB'D
Walk out in the morning to start it and it will start fine,
Run it for 10 minutes onward to 4 hours and shut it off and there is a 50/50 chance that it will start again.
Crank it over and when I let off the key, it will backfire/sound like it is trying to turn over, when the key gets to the nuetral position.
New Dist. cap, coil, plugs, and wires.
When the truck doesn't start I pull it with the tractor and it starts right away.
Any help?
460 CARB'D
Any help?
Woo Hoo, I bet you have a Holly 4180-C carburetor.
Sounds like the electric choke or a fuel vapor problem.
Look online or have your dealer print these Technical Service Bulletins
871913 September 1987
861219 June 1986
Sounds like the electric choke or a fuel vapor problem. Look online or have your dealer print these Technical Service Bulletins
861219 June 1986
I will try to find more info on those online but the is open when I try to start it, I will also close it and try to start it but the same thing happens. it is like it isn't getting spark or a sensor is out.
Thanks,
Anyone have an account?
Thanks,
