check engine light on
Old Jan 5, 2004 | 05:22 PM
j_yates78's Avatar
ok i need to find a good reasonable shop in the santa clara, ca area. the light is on and i need to have the codes checked. please let me know.
thanks
Old Jan 5, 2004 | 05:56 PM
my97offroad's Avatar
Whats your truck doing if anything? You can take your truck to autozone and they will pull the codes for you for free.
Old Jan 8, 2004 | 01:29 PM
hapynzap's Avatar
What kind of truck do you have? Yr engine etc?
I bet autozone will say you need o2 sensors but that's really not the problem heh.
keep us posted.
Old Jan 8, 2004 | 01:56 PM
j_yates78's Avatar
1997 Ford Expedition 5.4
ok, so i disconnected the battery and installed a new PCV. The check engine light has not come back on as of yet i have only driven it to work. (3 miles or so) The idle is rough and feels like it is going to die but then it automatically increases the rpm to 1500 then drops to 500 and back an forth in some cases it sticks at 1500 for a few seconds. the car seems to run fine above 1500rpm. The car has over 100k, but has had a tune up and fuel filter installed. what should be the next step to fix the rough idle issue? thanks.
Old Jan 8, 2004 | 04:20 PM
Throttle's Avatar
Follow the PCV hose into the back of the manifold. It sounds like you have a ruptured PCV elbow back there. The codes will come back if thats it. The codes will be p0171 & p0174. Autozone will pull the codes for free but check that elbow first. The elbow comes in the PCV hose assy from the dealer. It's about $25
Old Jan 8, 2004 | 05:11 PM
j_yates78's Avatar
thanks i will check it after work. at lunch the check engine light came back on.
thanks for all your help. Jason
Old Jan 15, 2004 | 03:46 PM
j_yates78's Avatar
OK, that seems to have taken care of the really rough idle and engine light. But i still have a problem with a slight shake every 2-4 seconds when i am parked and the engine is at idle. the shake is very slight, but i can feel it and when i accelerate the engine is slow to gain speed (especially between 1500-2000 rpm) it seems to not want to go over 2000 rpm when merging onto the freeway. I was todl it might be a bad coil plug but i thought i would look for some more expert advise. Please let me know if you have any ideas. everything i have received so far has been excelent advice. thank you.
jason
Old Jan 15, 2004 | 05:26 PM
Throttle's Avatar
If it were a coil pack, you would be getting a code P0301 through P0308 or possibly even P0300 Random Misfire. Did you have the codes pulled? If you don't have a ck eng light, you can rule out a lot of possiblilities and concentrate on fuel delivery. Let us know.
Old Jan 15, 2004 | 05:55 PM
j_yates78's Avatar
I did not have the codes pulled, will they still show if the check engine light has gone off?
Autozone will not pull the codes in California so that is not so good.
Fuel delivery, what areas should i look into? the fuel filter was recently replaced, maybe a few thousand miles ago. Should i consider a fuel system cleaner? which would be best? all your help is appriciated.
Thank you.
Jason
Old Jan 15, 2004 | 06:01 PM
jvangel's Avatar
Get under the truck and make sure the filter wasn't installed backwards. I've heard of this happening before. You never know......................................
Old Jan 15, 2004 | 06:41 PM
j_yates78's Avatar
i will check ASAP, if that is not the case what will be the other possibilities? I read some posts and i think this is the order and possible issues please let me know if this sounds right,
1. check fuel filter position
2. clean IAC
3. Coil packs (one may be bad?, there any way to check without a coder?) the reason i ask is because ford dealer wants $120.00 to check the codes i think that is ridiculous.
4. O2 sensor? not sure about this one.
Once again thank you all.
Jason
Old Jan 15, 2004 | 06:48 PM
Dennis Nicholls's Avatar
Angry
Yeah I just found out that AutoZone won't pull codes in California this week too.
I got a Equus 3100 scanner at Kragens: $99 net after rebate during January. I figure it's money well spent.
Old Jan 16, 2004 | 12:58 PM
Throttle's Avatar
For $120.00, the dealer had better do more than just pull a code. Are you sure that’s not a quote for a full diagnostic? At least you will get to read some outdated magazines and drink their bitter coffee.
California has some pretty strict regulations about automobile repair. The Bureau of Automobile Repair requires a work order/estimate anytime a second party touches a vehicle. This may be why Autozone allow it in CA.
Checking the filter flow direction and fuel pressure will eliminate a pump/filter problem.
Old Jan 21, 2004 | 08:05 PM
j_yates78's Avatar
where is the IAC? i have a chilton book, but i want to be sure i am cleaning the correct part. Please let me know.
Thanks.
Old Jan 22, 2004 | 06:14 AM
mf150's Avatar
Thank you.
Jason
Red Line SI-1 Fuel System Cleaner is the best 1 bottle fix.
