Cleaning MAS ??
Old Dec 5, 2003 | 04:39 PM
je3169's Avatar
Cleaning MAS ??
I read that you can use brake cleaner to clean the MAS is this true and what is the best thing to clean it with i did a search and not much came up on the subject.
TIA
John
Old Dec 5, 2003 | 04:44 PM
Hymis's Avatar
Brake cleaner would work, however alcohol and a Q-Tip would work the same. Would be more gentile on the sensor too. Hope this helps.
Old Dec 5, 2003 | 04:55 PM
Throttle's Avatar
Ditto on Hymis's reply and it's something you will find in your old lady's bathroom anyway. Be gentle and tread lightly on those wires.
Old Dec 5, 2003 | 08:19 PM
Bracketracer(2)'s Avatar
I used intake cleaner that was sensor safe,,, oil from the K&N gets on the wires and collects dirt,, the weight on the wires gives a false reading that shows up as "lean fuel left or right bank" Reset your puter after you have cleaned it,,, worked great for me
Old Dec 6, 2003 | 10:59 AM
je3169's Avatar
Thanks for the info guys.
John
